PIAA 1100x installation question
Old Jan 6, 2004 | 06:22 PM
night feeder's Avatar
night feeder
Default PIAA 1100x installation question
i cannot locate the purple wire that i need to splice into so the stock foglight switch will work to turn them off and on :confused: any help would be appreciated :cheers:
Old Jan 6, 2004 | 06:25 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: PIAA 1100x installation question (night feeder)
It's the small purple one under fuse #39 :yesnod:
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I'd be glad to go to the garage, take the cover off the car and see where I spliced into the wire..............but I need to head to the gym in a few minutes. If no one comes up with the location, I'll do it when I get back :seeya
night feeder
Default Re: PIAA 1100x installation question (ALLKAR)
thanks alot, that was giving me a headache :banghead:
[Modified by night feeder, 6:26 PM 1/6/2004]
Old Jan 6, 2004 | 06:27 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Don't cut it. Just splice!! :smash:
Old Jan 6, 2004 | 06:30 PM
dpd's Avatar
dpd
did your car come with factory fogs?ifnot,your car may not have the proper wiring.when you go to the fuseblock under the hood[where the relay is]i'm pretty sure it's fuse #6 that should have the purple wire to the switch.pop up the box and look[there are other purple wires there,but they are not the right ones. the relay[#39],should have a purple wire that goes from the relay to the fuse,from the fuse to the switch.
[Modified by dpd, 11:37 PM 1/6/2004]
Old Jan 6, 2004 | 07:23 PM
night feeder
Default Re: PIAA 1100x installation question (dpd)
yes it came with foglights... i unclipped the fuse box and took off the one bolt but i could only lift the fuse box probably about half an inch to see the wires, is there anyway i can lift it up anymore :confused:
Old Jan 6, 2004 | 08:29 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
It"s tight. I kind of angled mine & was able to get to the wire.
If that don't work, Get out the "BFH"!! :smash: :lol:
Old Jan 6, 2004 | 09:24 PM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Yes, that's an undisclosed problem with these "easy" :mad instructions: unclip the fuse box and loosen one bolt, and it still only comes up a few inches, what with all the wiring attached to it. Very awkward. The alternative is to splice into the purplie wire down at the original wiring to the lights themselves.
Old Jan 6, 2004 | 09:49 PM
Mag Red Monster
Elite Member
Default Re: PIAA 1100x installation question (pastorbrad)
Did you figure it out yet? :confused:
Old Jan 6, 2004 | 10:28 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
:iagree: ALLKAR knows :yesnod: He did mine and his. Once you remove the clips, you really can't lift the cover much. Let us know how it goes.
Old Jan 6, 2004 | 11:03 PM
night feeder
Default Re: PIAA 1100x installation question (98BlackMagic)
yea i figure it out about an hour ago. thank you forum members for the help!!! i was definetly lost with that purple wire :banghead: all i have to say is wow though, i dont know why i didnt put these on sooner :cheers:
also... about aiming these, i pointed them down as far as it goes pretty much and theyre still insanely brite :eek: is there any way to know i aligned them right so i dont blind anyone :lol:
[Modified by night feeder, 11:05 PM 1/6/2004]
Old Jan 6, 2004 | 11:24 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
If you used the stock brackets they are adjustable with an Allen wrench(don't remember the size) :thumbs:
Old Jan 6, 2004 | 11:45 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Mine are aimed about 10 feet or so in front of the vette, and they are really bright :eek: I don't really know if the alignment is that critical, unless you really have them pointed up. I just used my stock fog lamp brackets and went with that.
Old Jan 7, 2004 | 08:17 AM
Automag928's Avatar
Automag928
:iagree: I used the stock brackets, and didnt worry too much about adjusting and they look great, no flashes from oncoming drivers so it must not be too blinding to oncoming traffic.
Old Jan 7, 2004 | 09:02 AM
Mag Red Monster
Elite Member
Here's how I aimed mine. On a level surface park the car about 25' from a wall. Turn on your low beams and mark an x where the center of the beam hits the wall. Aim your Piaa's about 2-3 inches below the center line and a bit to the right of eack mark. I never get flashed. :thumbs:
To PIAA 1100x installation question
