Flickering Lights
Old Jan 7, 2004 | 05:39 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Flickering Lights
Yesterday my car had gremlins. My headlights would only pop up every other time they were turned on. Also my radio and HVAC display and headlights would flicker. I put the DIC on the battery voltage and it was dropping into the 13V's quite often.
Not sure if the headlights not popping up is related but it seems like my alternator might be going out? Anyone experience this flickering before?
Old Jan 7, 2004 | 05:40 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Flickering Lights (5 Liter Eater)
Check battery cables and especially the ground cable for good, CLEAN connections at all ends. That's a start.
Old Jan 7, 2004 | 05:44 PM
Oldvetter's Avatar
Oldvetter
Default Re: Flickering Lights (WhiteC5Vette)
:iagree: A lot of people said this was normal for a C5, but mine stopped when I found, and tighthened a loose battery cable. Be careful NOT to overtighthen, especially if you don't have a glass mat battery (I do have one), because this can cause the battery to leak around posts and destroy your car's computer.
[Modified by Oldvetter, 5:08 PM 1/8/2004]
Old Jan 7, 2004 | 05:58 PM
5 Liter Eater
St. Jude Donor '11
Default Re: Flickering Lights (Oldvetter)
It's an aftermarket battery so I'm not worried about leakage. I'll check the cables.
Old Jan 8, 2004 | 10:32 AM
5 Liter Eater
St. Jude Donor '11
Checked the cables and the + and - were both fairly loose. After tightening them last night no flickering this morning.
Thanks again. :thumbs:
To Flickering Lights
