new shifter
Old Jan 11, 2004 | 01:09 AM
DelMonteZO6's Avatar
DelMonteZO6
Default new shifter
Im looking for a new shifter. Whats good and where can I get them. Basically I just want a shorter one. Not short throw...but shorter height. I took mine out tonight to cut and weld it but its a little different than I expected.
Old Jan 11, 2004 | 01:30 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: new shifter (DelMonteZO6)
Check out this thread. http://forums.corvetteforum.com/zerothread?id=727842
Old Jan 11, 2004 | 07:47 AM
vettenuts's Avatar
vettenuts
Default Re: new shifter (ALLKAR)
Scan the parts for sale for a used stock one, that way if you run into a problem or don't like the results you will still have your original.
Old Jan 11, 2004 | 10:56 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Welcome to the Forum.
I have a shorten shifter and will try to send you a picture.
:auto:
Old Jan 11, 2004 | 12:38 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: new shifter (vette#one)
Buy a Hurst and get ride of your dilemma. :thumbs: :seeya
Old Jan 11, 2004 | 01:09 PM
Skyguy^^'s Avatar
Skyguy^^
What you need to do is: cut off a portion of the top of the shaft, an inch or so, and using a 9/16x18 die, run threads further down the shaft. This is the easiest, cheapest way. :cheers:
Old Jan 11, 2004 | 02:12 PM
vettenuts's Avatar
vettenuts
Default Re: new shifter (Skyguy^^)
Can you get the original boot and shift **** back on this way?
Old Jan 11, 2004 | 02:24 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
There are a few shifters on the market.. : kirban, hurst, B&MRipper, breathless performance... they are all shorter than stock... I have Ripper, and love it.. Ive had it three years... many people hate them because they require more effort than most... you can buy a used short shifter from the forum used parts section... some one is always selling a hurst or kirban... I never see a ripper being sold... although with all the post against them.. I would imagine they get sold frequently.. I just never see them for sale...I love the preciseness of a ripper...
Old Jan 11, 2004 | 03:38 PM
Skyguy^^'s Avatar
Skyguy^^
Default Re: new shifter (vettenuts)
The short answer: not really.
Long answer:
The original **** requires the slot in the aft side of the shift lever. The lever could be milled, extending the slot further down before it was re-threaded. The original boot could be shortened, but would probably look better to just buy a shortened one from Ken at Vette Essentials.
Hope this helps :cheers:
Old Jan 11, 2004 | 03:51 PM
Noggles's Avatar
Noggles
From: Adventure, excitement ... a Jedi craves not these things.
Cruise-In VII Veteran
lots of archived threads on this.
Old Jan 11, 2004 | 04:55 PM
Skyguy^^'s Avatar
Skyguy^^
Default Re: (Noggles)
Like this: http://benelliwang.badassride.com/Sh...ex.html#Second Mod
:cheers:
Old Jan 12, 2004 | 04:11 AM
DelMonteZO6
Default Re: (Skyguy^^)
Im reading about people putting silicone sealer on the shifter??? Where does this go and what does it do?
Old Jan 12, 2004 | 02:50 PM
DelMonteZO6
Default Re: (DelMonteZO6)
does anyone that has put in an aftermarket shifter want to get rid of the stock?? I have searched in the parts for sale but I thought maybe someone might hvae sitting around that I could get?
To new shifter
