C6 BLOCK
Old Jan 20, 2004 | 04:38 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default C6 BLOCK
Hey guy & gals,
what do the chances of the c6 block working with c5 heads cam ect. it would be nice to buy c6 block and then get stroker kit to make it ??? gotta be more reliable then these sleeved ones out there. chime in. :blueangel:
[Modified by NICK YOSKIN, 9:39 PM 1/20/2004]
[Modified by NICK YOSKIN, 9:42 PM 1/20/2004]
Old Jan 20, 2004 | 04:47 PM
cb5300's Avatar
cb5300
Default Re: C6 BLOCK (NICK YOSKIN)
I was told that the C6 block wouldn't work in the C5...... :cry
Old Jan 20, 2004 | 04:51 PM
NICK YOSKIN
St. Jude Donor '08
Default Re: C6 BLOCK (cb5300)
I hope your wrong :cry :cry :cry :cry :cry :cry
Old Jan 20, 2004 | 06:12 PM
427 C5's Avatar
427 C5
Jim Hall posted that the heads will be interchangeable.
I hope that the blocks are compatible as well.
Old Jan 20, 2004 | 06:58 PM
RoadRebel's Avatar
RoadRebel
Default Re: C6 BLOCK (427 C5)
Blocks are a ton different...I am pretty sure the heads will not work either.
The knock sensors are moved from the valley area. The main changes in the block is the oil drain/ventilation system. COMPLETELY different, you will find the valley cover is used to cap multiple vent/drains built into the interior of the block instead of using the outboard drainbacks.
Phil
To C6 BLOCK
