Ran at the track for the first time
Old Jan 21, 2004 | 08:08 AM
Automag928's Avatar
Automag928
Default Ran at the track for the first time
Well, last Thursday was the first time I ran my car at the 1/4 mile track down in Bradenton. I was a little dissapointed with the times, but I only got two runs in (btw, anyone know of decent helmets that arent too expensive?). I'm sure with some practice I can get the times lower but anyways, here they are --
1st run - 2.4 60' 13.6 @ 106
2nd run - 2.6 60' 14.4 @ 105 (Left the dang TC on!! DOH!! :banghead: )
This is on the stock run craps and tire pressures left as is (30psi cold/34 hot)
I defintely cant wait to run it again - for those of you that havent done it, its an absolute blast!
Old Jan 21, 2004 | 08:21 AM
ROJO99's Avatar
ROJO99
Default Re: Ran at the track for the first time (Automag928)
Congrats on your first runs, and becoming another track junkie :hurray: .
I also went for the first time last year and our first run results were very similar.
Like myself you need to get your 60' down to 2.0 this will greatly improve your times. The standard figure for an easy conversion is that for every .1 that you reduce your 60', it will equal .15(Appox.) at the finish. I have run a best of 13.22@109.2MPH. I am on a quest to hit 12's before any mods. Good luck and keep it on the track. :D ... :flag
Old Jan 21, 2004 | 08:56 AM
TLewis4095's Avatar
TLewis4095
Welcome to the addiction of drag racing Jay!!
A4 or MN6? I expect to see you at the corvette challenge series of races this year! http://www.flacorvettechallenge.com We have our banquet this weekend so probably won't be there, but get back out & practice! We only ran 13.98 bone stock.
At Bradenton they have the new LED lights on the tree so a .000 is a perfect tree.
Go to http://www.corvettechallenge.info as well for good tips on racing your vette.
Feb 14th is the first race...9AM! Be there, we give free instructions on bracket racing!! Any inexpensive helmet from a motorcycle shop will do. :cheers: :thumbs:
Old Jan 21, 2004 | 09:05 AM
Automag928's Avatar
Automag928
Default Re: Ran at the track for the first time (TLewis4095)
Its an MN6. My R/Ts were .39X and .4XX something...That was a change for me... I thought I had red lighted my first run, my brain was still working off of the .500 tree. I'm going to try and go more often...Like I said before it was a total blast!
niphilli2's Avatar
niphilli2
Looks like you are doing a good job shifting, just a little practice leaving the line and you will be running low 13s :)
Old Jan 21, 2004 | 09:58 AM
ROJO99's Avatar
ROJO99
Default Re: Ran at the track for the first time (niphilli2)
I purchased my helmet from Mejiers, 55.00 dollars...
Old Jan 21, 2004 | 01:33 PM
Not bad for first time runs. Like you said, practice will make the times drop.
Old Jan 22, 2004 | 02:46 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Ran at the track for the first time (ROJO99)
Work on that 60ft and your times will look alot better! :cheers: :thumbs: :yesnod: :auto:
Old Jan 22, 2004 | 10:54 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Welcome to drag racing.
Yes practice will make you better. Drag Radials will also help you with hooking properly and consistently. It should be everyones first mod for the track :)
Are you close to Bradenton at all?
Old Jan 22, 2004 | 11:01 AM
Caillou's Avatar
Caillou
Default Re: Ran at the track for the first time (LittleBoyBlu99)
:iagree: :cheers: :thumbs:
Old Jan 22, 2004 | 12:13 PM
Jackal's Avatar
Jackal
Welcome to the other sickness....the one other than the mod sickness. Some how the two sicknesses are tied together......;)
Old Jan 22, 2004 | 03:50 PM
Automag928's Avatar
Automag928
Default Re: Ran at the track for the first time (REDGAR)
Not really...its about an hour depending on the drive down and who I am caravan'ing with! ;)
Old Jan 22, 2004 | 03:55 PM
TLewis4095's Avatar
TLewis4095
Once a month you will be caravaning with the rest of the Corvette Challenge racers, right? :D
Old Jan 23, 2004 | 01:07 AM
MC TORCH RED's Avatar
MC TORCH RED
get you a set of nitto drag radials and you will drop about .6 tenths off you 1/4 times good luck. your 60ft times are killing you.
Old Jan 23, 2004 | 07:58 AM
vstella's Avatar
vstella
Default Re: Ran at the track for the first time (MC TORCH RED)
get you a set of nitto drag radials and you will drop about .6 tenths off you 1/4 times good luck. your 60ft times are killing you. ..MC TORCH RED
:iagree:
Old Jan 23, 2004 | 12:10 PM
white shark's Avatar
white shark
Default Re: Ran at the track for the first time (vstella)
:iagree: the 60ft times kill ya
Old Jan 23, 2004 | 12:23 PM
RWhite's Avatar
RWhite
Default Re: Ran at the track for the first time (white shark)
Looks like another patient, Dr. Vince! :D
Old Jan 24, 2004 | 12:59 AM
MC TORCH RED
Default Re: Ran at the track for the first time (RWhite)
thats a good name for him..... :iagree: :thumbs:
To Ran at the track for the first time
