Cam degreeing, what's involved?
You will need a degree wheel, dial gauge (way to find top dead center as cam is actually in crank degrees), pointer reference and the engine on a stand to do this the right way. Note, I have degreed many comp cams, crane and a few other brands, and almost every one I've checked were within 1/2 to 1 degree of the lobe centers advertised keeping in mind the timing chains are sometimes slack.
Anyway, using a degree wheel/dial gauge, you can actually monitor the opening and closing events of the cam by watching the lift on the dial gauge and the degree wheel. Its also a good time to measure total lift. I always liked this process especially when comparing cams at low lift #s, like 0.2, 0.3, 0,4" etc, gives you a good idea how agressive the cam is. In the end, you can degree it by verifiying the calculated lobe center based on your degree data. A word of caution. Most aftermarket cams already have advance ground in. So make sure you don't change the cam timing without thoroughly going over the cams specs.
ANyway, too many words to describe the process. Try reading the help on comp cams website or maybe its the crane site. ONe of them has a how to degree cam pdf.
However, iskycams.com has a comprehensive tutorial that should get you up to speed, (so to speak).
Advancing or retarding the camshaft in the engine, with relation to the crankshaft, helps the builder tailor power and torque for a specific rpm band, and specific circumstances, i.e. coming off corners of circle tracks, compensating for ambient conditions or altitudes, stickier dragstrips, etc.
Most enthusiasts (and shops) will install aftermarket cams "straight up", although as previously mentioned, many cams are ground with 2-4 degrees of advance, enhancing bottom end performance.
Not many, outside of serious racing endeavors, will choose to dismantle their car just to move the cam a couple of degrees, and shops installing cams won't spend half a day verifying what is already printed on the cam card.
