Cam size??
Old Jan 22, 2004 | 10:18 PM
Fastbasser's Avatar
Fastbasser
Default Cam size??
What lift can you go to without needing to replace valve springs on a regular basis? .550,,, .560 ect??
What can I expect as far as a hp gain with a lift such as this?
Thanks in advance..
Old Jan 23, 2004 | 12:39 PM
Mr. Jones's Avatar
Mr. Jones
Default Re: Cam size?? (Fastbasser)
is this an ls1 or ls6
ls1-i would think .525 lift not sure?
ls6-.550-.560 tops
some poeple experienced valve float in the ls6 with the
stock cam. SLP has some low lift cams approx .525 check their site.
i would recomend cam, springs and harden pushrods- do it this way and have a sound reliable setup. its not much more work to install the springs
Old Jan 23, 2004 | 01:07 PM
mcd_57's Avatar
mcd_57
Default Re: Cam size?? (Mr. Jones)
:iagree: Do good springs so you can go as big as you want. :lurk:
Old Jan 23, 2004 | 03:23 PM
C5JONNY's Avatar
C5JONNY
Default Re: Cam size?? (mcd_57)
:iagree:
To Cam size??
