Squeeking Steering wheel...is there a TSB on this?
Old Jan 22, 2004 | 10:59 PM
jmX's Avatar
jmX
Default Squeeking Steering wheel...is there a TSB on this?
I know I've heard of a few C5 steering wheels making noise. I believe my car actually had the issue fixed by the previous owner, but now the noise is returning. Kinda annoying...anybody fixed this? C5-Tech maybe has come across this before?
Jon '99 C5
http://www.ls1howto.com
Old Jan 22, 2004 | 11:47 PM
racetchr's Avatar
racetchr
Default Re: Squeeking Steering wheel...is there a TSB on this? (jmX)
I think it has been isolated to one of two of the steering shaft bushings. I know mine is coming from the upper one. Unfortunately I cant tell you how to fix it - but I am going under the dash this weekend. Its driving me :crazy:
Old Jan 23, 2004 | 12:09 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Common problem...You need to lube the lower column nylon bushing or replace it.The bushing is located in the rubber grommet in the fire wall and is accessed from under the hood.
I believe that there is a write-up in Tech-Tips :yesnod:
Old Jan 23, 2004 | 01:04 PM
B. Stewart's Avatar
B. Stewart
Default Re: Squeeking Steering wheel...is there a TSB on this? (C-5 TECH)
Mine turned out to be the upper bushing. Spray some lithium grease where the shaft turns in the white nylon bushing. http://forums.corvetteforum.com/zerothread?id=727771
[Modified by B. Stewart, 12:11 PM 1/23/2004]
Old Jan 23, 2004 | 06:43 PM
Fast98's Avatar
Fast98
Default Re: Squeeking Steering wheel...is there a TSB on this? (B. Stewart)
Yup I just fixed this on mine it was the upper bushing,just lube it and it will be fine. :chevy
To Squeeking Steering wheel...is there a TSB on this?
