Rear and Trans fluid recommendations.....
Old Jan 23, 2004 | 07:55 AM
SmoothFRC's Avatar
SmoothFRC
Default Rear and Trans fluid recommendations.....
I have the dreaded rear leak problem....
I figured since they will be re-sealing the rear, i mine as well have them change the fluid anyway.... and while they are under their - let's do the trans also.
So with that said.... What is a good replacement fluid for these items? and capacities...
[Modified by SmoothFRC, 7:24 AM 1/23/2004]
[Modified by SmoothFRC, 8:07 AM 1/23/2004]
Old Jan 23, 2004 | 08:41 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Rear and Trans fluid recommendations..... (SmoothFRC)
Capacities?? depends..MN6 or Auto
lots of guys using Redline I am running Amsoil
edit:couldnt remember Amsoil :rolleyes:
[Modified by pewter99, 8:42 AM 1/23/2004]
Old Jan 23, 2004 | 08:43 AM
pewter99's Avatar
pewter99
Default Re: Rear and Trans fluid recommendations..... (pewter99)
see this thread for specs http://forums.corvetteforum.com/zerothread?id=734344 :seeya
Old Jan 23, 2004 | 09:07 AM
SmoothFRC's Avatar
SmoothFRC
Amsoil for BOTH or just the rear and maybe redline for the trans?????
Old Jan 23, 2004 | 11:46 AM
carpe dm's Avatar
carpe dm
Who is going to do the work? A GM dealer? Will theyuse anything other than GM fluids? The reason I ask, is because I have known several that will only use GM stuff. That said, I would use Amsoil if possible. :yesnod: :)
Old Jan 23, 2004 | 12:19 PM
Richin Chicago's Avatar
Richin Chicago
Redline 75w90 for the diff. 2 quarts and it already has the friction modifier mixed in. http://www.myoilshop.com/SynGrOil.html
Redline D4 ATF 4 quarts for MN6. http://www.myoilshop.com/ATF.html
I have been using both for years. Good for the street and added protection if you run track events.
Old Jan 23, 2004 | 01:50 PM
sasunlover's Avatar
sasunlover
I just developed the leak myself. The car is out of warranty. How much can I expect to pay to have this fixed?
Old Jan 23, 2004 | 01:54 PM
jojog's Avatar
jojog
Default Re: Rear and Trans fluid recommendations..... (sasunlover)
My leak stopped when I switched to Redline. Could have been a case of factory/dealer overfill but it didn't pour out when I pulled the plug. I think Redline causes minor seal swelling. :thumbs:
Old Jan 23, 2004 | 04:17 PM
FKING1's Avatar
FKING1
Default Re: Rear and Trans fluid recommendations..... (jojog)
No leak but I went to RedLine D4ATF in the tranny and 75/90 gear oil for diff. Trans shifting was notably smoother. Rear end, who knows but made me feel good! As a bit of useless info, just changed my 04 Mustang Cobra to GM Syncromesh which works better in the T56 trans than RedLine per the SVT Forum majority of Cobra people. Apparently RedLine affects the seals in the Mustang trans.
Fred k. :steering:
Old Jan 23, 2004 | 04:29 PM
IMQUIK's Avatar
IMQUIK
Amsoil it all!! :yesnod:
Old Jan 24, 2004 | 03:57 PM
KF9BD's Avatar
KF9BD
Default Re: Rear and Trans fluid recommendations..... (IMQUIK)
Which amsoil product are you using in the transmission, UAT or somethingelse?
Old Jan 24, 2004 | 04:11 PM
racetchr's Avatar
racetchr
I was wondering about cost as well-gotta do mine now :cry
Old Jan 24, 2004 | 06:38 PM
IMQUIK's Avatar
IMQUIK
Default Re: Rear and Trans fluid recommendations..... (KF9BD)
<A HREF="http://www.amsoil.com/products/atf.html" TARGET="_blank"> http://www.amsoil.com/products/atf.html</A>
Retail $7.55
[Modified by IMQUIK, 6:39 PM 1/24/2004]
Old Jan 27, 2004 | 04:03 PM
IMQUIK's Avatar
IMQUIK
Your gear lube & ATF are on the way. :thumbs: Thanks. :flag
To Rear and Trans fluid recommendations.....
