Proper Technique For Measuring Dipstick level?
Old Jan 23, 2004 | 04:15 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Proper Technique For Measuring Dipstick level?
Car Cold and Turned Off Or Car Cold and turned ON?
Old Jan 23, 2004 | 04:39 PM
IMQUIK's Avatar
IMQUIK
Default Re: Proper Technique For Measuring Dipstick level? (MARK's_C5TT)
Warm and off. (that is what I do)
:D
Old Jan 23, 2004 | 05:05 PM
gmblack3's Avatar
gmblack3
Default Re: Proper Technique For Measuring Dipstick level? (IMQUIK)
I usually check mine in the morning or when cold. :crazy:
Old Jan 23, 2004 | 05:25 PM
beebs52778's Avatar
beebs52778
Default Re: Proper Technique For Measuring Dipstick level? (gmblack3)
Warm and off. :auto:
Old Jan 23, 2004 | 08:07 PM
hotrodhoodlum's Avatar
hotrodhoodlum
8th Gear
Default Re: Proper Technique For Measuring Dipstick level? (beebs52778)
If you check your oil with the car running,, please quit driving ....you can check the trans with it running, but shut off the motor to check you oil,, dont matter if its hot, cold or warm ,, but you must wipe the dipstick on your pants to obtain a correct reading
Old Jan 23, 2004 | 11:39 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: Proper Technique For Measuring Dipstick level? (hotrodhoodlum)
Check the oil after your engine has reached normal operating temperature. Park on a level surface, shut the engine off. Wait a couple minutes. Pull out the dipstick and wipe it clean. Insert the dipstick all the way and immediately pull it back out. Read the level.
For an auto tranny, park on a level surface and leave the engine running with the tranny in nuetral. Use the same dipstick procedure.
To Proper Technique For Measuring Dipstick level?
