I just back from the DynoJet
Old Jan 24, 2004 | 07:20 PM
4deatr's Avatar
4deatr
Default I just back from the DynoJet
With the list of mods I have a put down 319.81 rwhp and the torque was 400. I quess I have a lot of work to do to keep up with the big dogs. But I guess not to bad with the little performance mods I have done.
Old Jan 24, 2004 | 08:14 PM
RyanC7's Avatar
RyanC7
Default Re: I just back from the DynoJet (4deatr)
Performance- Vararam Ram Air System, Trans Go Shift Kit, GHL Exhaust, Magnaflow X-pipe, power duct, air coupler, modified MAFS, throttle body bypass, performance hood seal.
:thumbs:
Old Jan 24, 2004 | 08:22 PM
4deatr's Avatar
4deatr
Default Re: I just back from the DynoJet (Ryan2002C5)
:thumbs:
Yep
Old Jan 24, 2004 | 08:52 PM
Dave00C5's Avatar
Dave00C5
:cool: :cheers: :cheers: :thumbs:
Old Jan 25, 2004 | 12:34 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: I just back from the DynoJet (Dave00C5)
Your torque was 400 at the tires? Kaley
Old Jan 25, 2004 | 12:46 AM
Brian@KelleyPerf's Avatar
Brian@KelleyPerf
Decent numbers but look at your dyno graph.. you will probably see that the torque reading of 400 if you are reading it correctly is probably a spike and not the real torque rating.
Old Jan 25, 2004 | 01:52 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: I just back from the DynoJet (Brian@KelleyPerf)
Yeah, the Hp sounds good but the torque sounds about 100 off.
Old Jan 25, 2004 | 09:49 AM
4deatr's Avatar
4deatr
Default Re: I just back from the DynoJet (lowdowndirty)
For some reason the torque would not read and he had to work it with the mph. So he did the math on it and came up with 400 but not to the rw. The chart shows 750 torque and I know that is not right. He said he could not get a good ground.
Old Jan 25, 2004 | 10:05 AM
pdd000's Avatar
pdd000
:iagree:
Old Jan 25, 2004 | 02:54 PM
:cool: :thumbs:
Old Jan 26, 2004 | 10:59 AM
ChasNMe's Avatar
ChasNMe
so how did everyone else do? what did you guys think of the tuning? are we gonna plan this again? i had to work all weekend :(
Old Jan 26, 2004 | 12:35 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
\With the list of mods I have a put down 319.81 rwhp and the torque was 400. I quess I have a lot of work to do to keep up with the big dogs. But I guess not to bad with the little performance mods I have done.
:iagree: :thumbs:
Old Jan 26, 2004 | 01:58 PM
gojo's Avatar
gojo
You can calculate the torque. Plug in your numbers to this formula.
torque =HPx5252/RPM's at which peak power made.
Old Jan 26, 2004 | 07:19 PM
4deatr's Avatar
4deatr
Default Re: I just back from the DynoJet (ChasNMe)
I'm not sure how everyone did. I could see us do this again we had a great turn out.
To I just back from the DynoJet
