Service tire monitors????
Old Jan 27, 2004 | 07:56 PM
Rogerc5's Avatar
Rogerc5
Default Service tire monitors????
My new '04 (36miles) had Service Tire Pressure Monitor come up. Any way to reset code to see if it does it again or take back to the dealer. A pain in the butt.
Roger
rogerc5
Old Jan 27, 2004 | 08:31 PM
JAvery20's Avatar
JAvery20
Default Re: Service tire monitors???? (Rogerc5)
did you try checking your tire pressure? That came up on my moms car(01) a couple of times when all the tires were low on air. Just make sure you get all the tires above 25 psi. It's really hard to tell if you low on air w/ these stiff sidewalls.
Good luck
Old Jan 27, 2004 | 08:43 PM
Rogerc5's Avatar
Rogerc5
Default Re: Service tire monitors???? (JAvery20)
Thanks for the reply. The tire pressures are 30 to 32lbs. Must be something else. Thanks anyway.
Roger
To Service tire monitors????
