winkin and blinkin
Old Jan 27, 2004 | 09:05 PM
danielschulzjr's Avatar
danielschulzjr
Default winkin and blinkin
I hope someone has experienced thi and can tell me if its the gear or do I have a bigger problem. Seems the right headlight goes up and down just fine, but once it goes down the motor continues to run for about 30 seconds, sounding like its grinding glass then just stops. Any help greatly appreciated!
Old Jan 28, 2004 | 01:06 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: winkin and blinkin (danielschulzjr)
This is a prime indication that you have a stripped nylon gear! :eek: Get a NEW brass gear and rebuild the head light motor. Then you will NEVER have to worry about it again! :D
BC
Old Jan 28, 2004 | 07:08 PM
danielschulzjr
Default Re: winkin and blinkin (Bill Curlee)
Thanks for your help, I ordered a bronze gear last night. The exact same thing happened 20 years ago with my 85, you would think after this much time GM would have figured out how to prevent this.
Old Jan 28, 2004 | 08:28 PM
msuc5vette's Avatar
msuc5vette
I'm sure they knew how to prevent it in '85, but they've saved $0.18 on every Vette since then by sticking with nylon.
Old Jan 28, 2004 | 09:58 PM
cortex's Avatar
cortex
Default Re: winkin and blinkin (msuc5vette)
:banghead: I wish I would have seen this yesterday! I had the same problem and a fellow forum member informed me that only half the gear is used. You can follow these directions (look about 2/3rds down the page) to fix it. Worked great...
http://www.bfranker.badz28.com/headlightfix/
Old Jan 30, 2004 | 12:45 AM
danielschulzjr
Default Re: winkin and blinkin (cortex)
I wish you would have seen it also. That article was great. I did the repair and it took about twenty minutes. I will keep the bronze gear as stock, because I know its going to eventually wear out again. There ought to be a way we could put this fix in the "tech tips" section.
To winkin and blinkin
