Need a wastegate?
-Blue anodized (natural shown)
-44mm Valve (Internal or external seat available)
-Billet stainless base (not a casting)
-1 Piece stainless steel valve
-Aircraft quality aluminum cover
-Molded diaphram bonded to Nomex reinforcement
-Precision bronze valve guide
-Conservatively rated up to 750Hp
-Two units have easily controlled a 1400Hp car and 1500Hp boat
-3 boost ranges available (4-12)(13-22)(22-30)
Pricing
-Inernal seat Wastegate $359.99$ale $319.99
-External seat Wastegate $349.99$ale $309.99
-Flange $19 each inlet or outlet
-Additional springs $8 each
Supplies are limited, expires 2/15 or when we run out.
Shoot me an email if you want to order Tom@ls1speed.com
Tom
http://www.c5speed.com
1866Ls1speed.com
I might be interested in two with flanges . We are building a twin turbo LS1 Pro Touring 62' Nova. Starting to gather parts for the power train right about now.
Looking to run boost levels between 12-18 psi. How will they be in that range? Also can an electronic boost controller be tied into these?
What is the difference between internal and external seat with respect to it's operation?
[Modified by 9D9LS1, 9:37 PM 1/28/2004]
We are using these in a twin turbo 427 car we are building right now, and we plan on running 20+#.
THey will work with an electronic controller, we use the Innovative controller.
Tom
