trans go shift kit
Old Jan 28, 2004 | 08:29 PM
rollinred's Avatar
rollinred
Default trans go shift kit
who out there are using the trans go shift kit ?and how much of a difference does it make on a modded c5? :confused:
Old Jan 28, 2004 | 09:17 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: trans go shift kit (rollinred)
The transgo is the only way to go! :yesnod: It makes the shifts firm and quickwhen needed and you don't have to use high line pressure to shift which is a big help on the tranny. :thumbs: :cheers:
Old Jan 28, 2004 | 09:27 PM
rollinred's Avatar
rollinred
Default Re: trans go shift kit (LittleBoyBlu99)
which gears do you have?
Old Jan 28, 2004 | 10:00 PM
LittleBoyBlu99
I have 3.42's but hope to have 3.90's by late spring. :cheers:
Old Jan 29, 2004 | 12:19 AM
MC TORCH RED's Avatar
MC TORCH RED
:eek: trying to get faster uh. :sad:
Old Jan 29, 2004 | 06:06 PM
rollinred's Avatar
rollinred
Default Re: trans go shift kit (MC TORCH RED)
yes torch red trying to get where you are :thumbs: just wanted to make sure the trans shift was worth it along with the new 342's i am about to get installed :thumbs:
Old Jan 29, 2004 | 06:58 PM
vstella's Avatar
vstella
The transgo is the only way to go! :yesnod: ... LittleBoyBlu99
:iagree: :thumbs: More info here www.transgoperformance.com
Now view the video and listen carefully to the shifts... :yesnod:
http://temp.corvetteforum.net/c5/vstella//1111.wmv
[Modified by vstella, 6:59 PM 1/29/2004]
Old Jan 30, 2004 | 12:46 PM
BHP's Avatar
BHP
You must have it. The stock tranny shifts like a lazy dog.
Old Jan 30, 2004 | 08:26 PM
rollinred's Avatar
rollinred
Default Re: trans go shift kit (BHP)
please fellows give me more input, i ordered a kit today :thumbs: will it bark in second? :rolleyes:
Old Jan 30, 2004 | 08:38 PM
BHP's Avatar
BHP
With 3 washers at wot it will kick your butt! :D
Old Jan 30, 2004 | 08:39 PM
vstella's Avatar
vstella
... will it bark in second? :rolleyes:
Bark?....It will kick you in the AZZ like a truck hit you from behind...Relax..You will LOVE it and wonder why you waited so long. :yesnod:
One piece of advice ..get a qualified trans tech to install it!! :yesnod: If you have a problem finding one call transgo for a referral in you area.. :thumbs:
Old Jan 30, 2004 | 08:46 PM
rollinred's Avatar
rollinred
Default Re: trans go shift kit (vstella)
thanxs vstella i have a good mechanic he has lots of experience working on c5's btw the way your car is awesome :thumbs: i have seen it in serveral videos :thumbs:
Old Jan 31, 2004 | 10:52 AM
IMQUIK's Avatar
IMQUIK
:eek: WOW! :eek: That sum bench shifts SWEET! :thumbs:
Old Jan 31, 2004 | 01:13 PM
2FAST4U's Avatar
2FAST4U
Default Re: trans go shift kit (IMQUIK)
I got it installed when, and I like it. I had it set for street/strip. I would recommend doing this mod with a torque converter and rear gears of 3.42.
This will make you quite a bit faster, and the SOP much greater.
:seeya
Old Jan 31, 2004 | 02:16 PM
TLewis4095's Avatar
TLewis4095
Default Re: trans go shift kit (2FAST4U)
Excelent choice!!! One word of caution though!! Make SURE you do not have the line pressure increased any more than 15% by programing!!! This combined with the increase that is acomplished manually by the shift kit can cause spikes of line pressure that cause pressure to blow by the seal and momentary slippage of the 2-3 clutch pak. Burns it up in no time.
With the transgo you should need very little programed line pressure increase since the Transgo does a good job by it's self!! :thumbs:
To trans go shift kit
