SPEC stg 3 chatter problems SOLVED!
Old Jan 29, 2004 | 09:43 AM
Mike TexaSS's Avatar
Mike TexaSS
Default SPEC stg 3 chatter problems SOLVED!
My spec stg 3 clutch never seemed to break in right. It would chatter real bad from a stop in first gear. I had all stock 99 clutch master and slave. I recently had my trans rebuilt under warranty and while they had it apart i added a z06 Shift fork, 04 Z06 Clutch master and 04 Z06 Slave put in. I only had to pay 200 bucks in labor for a slave and master install. All new fluids too.
Well i got her back yesterday and its like a new car! The clutch clamps so much smoother no chatter at all! I can feel the difference in the clutch pedal!
Much firmer!
Thought i share my experience! :hurray:
Old Jan 29, 2004 | 11:57 AM
pdd000's Avatar
pdd000
Default Re: SPEC stg 3 chatter problems SOLVED! (Mike TexaSS)
:cheers: :cheers:
Old Jan 29, 2004 | 04:03 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: SPEC stg 3 chatter problems SOLVED! (pdd000)
Is the new master needed as well as the slave? I know the slave is important but have been told diff opinions on the master. Thanks, Kaley
Old Jan 29, 2004 | 05:01 PM
Targa C5's Avatar
Targa C5
Hi Mike,
SPEC recommends a new 2001+ Corvette Master and Slave with the installation of the new clutch unless you already have a 2001+ Corvette and your master and slave are in excellent condition. The Z06 and non-Z06 Corvettes, MY 2001+ use the same master and slave components. All current SPEC III clutches ship with an enclosed document explaining this recommendation. Glad to hear you got the problem solved! :cheers:
BTW, we are still running a special on the SPEC III and SPEC II/III with either flywheel.
Details: http://tigersharkcorvette.com/Mercha...egory_Code=775
2C5only21, yes you should install both a new 2001+ Master and Slave with a new SPEC III clutch.
Old Jan 29, 2004 | 05:14 PM
allanlaw's Avatar
allanlaw
Default Re: SPEC stg 3 chatter problems SOLVED! (Keith@TigerShark)
Keith, do you know the cutoff for a 2001+ master and slave. I have an '01 Coupe VIN number past 18000. I'm getting some "pedal stays down" action on high rpm downshifts.
Old Jan 29, 2004 | 05:19 PM
Targa C5's Avatar
Targa C5
Default Re: SPEC stg 3 chatter problems SOLVED! (allanlaw)
I can tell you the part numbers for the 2001+ master and slave. Maybe you can check with your service department for the rest.
GM part numbers are 12562767 and 12564455. Hope this helps!
Old Jan 29, 2004 | 06:10 PM
JYC5's Avatar
JYC5
Mike, what's a shift fork? Why would this help? I have same clutch/fly and upgraded to a new master/slave, but still get chatter and scheeching. :banghead:
Old Jan 29, 2004 | 07:14 PM
EFI-1's Avatar
EFI-1
Default Re: SPEC stg 3 chatter problems SOLVED! (JYC5)
Nice fix! :cheers: :thumbs:
Old Jan 29, 2004 | 07:16 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
The clutch will never slip but the clatter will return as it starts to wear, when I took mine out recently it was shot but served well while it was there, the Exedy dual (drove it today for the first time) needs no breakin and talk about clamping power I am very pleased with it, smooth shifts no clatter and damn sure no slip--
Old Jan 29, 2004 | 07:39 PM
cfi_luz's Avatar
cfi_luz
Default Re: SPEC stg 3 chatter problems SOLVED! (NEPTUNEBILL)
Can you please tell me more about the exedy setup, I am looking for a new setup, either this or the mcleod. thanks
Old Jan 30, 2004 | 12:01 PM
Mike TexaSS
Default Re: SPEC stg 3 chatter problems SOLVED! (cfi_luz)
The stock shift fork in a 99 FRC is made out of aluminum. I bent it and trashed my tranny. The 03 and up Z06's have a revised STEEL shift fork. Its stronger so you can slam gears!
Old Jan 30, 2004 | 05:01 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Nothing against what you said Bill but don't you think it is a little early if you just drove it (today for the first time) to be stating that it has no chatter and smooth shifts? I am sure it will not slip b/c of the dual design but to say it will never chatter is something else if you just installed it. I would be knocking on wood...
Sounds like a nice clutch though.
Old Jan 30, 2004 | 05:55 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: SPEC stg 3 chatter problems SOLVED! (C5-VERT)
mike bring the c-5 in the morning, and leave that beast SS at the house.. :D
To SPEC stg 3 chatter problems SOLVED!
