Downshifting
Old Jan 31, 2004 | 07:20 PM
ddmau's Avatar
ddmau
Default Downshifting
I read a post from a professional driver the other day who stated downshifting to slow the car will eventually harm the engine. This is how I've always operated my vehicles. Have I been wrong all these years? Hope not cause I love the sound of those Borlas doing their thing while slowing for the light, etc. :steering:
Old Jan 31, 2004 | 08:12 PM
Paras's Avatar
Paras
Default Re: Downshifting
I've heard that its ok as long as you rev match. (My novice knowledge.) It also seems to have to do with downshifting smoothly. I'm sure that no matter what it wears on the clutch.
Old Jan 31, 2004 | 08:41 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Default Re: Downshifting (ddmau)
Driving wears out the engine. :steering:
Old Jan 31, 2004 | 09:48 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Downshifting (03Ragtop)
:yesnod: :lol: :lol: :thumbs:
Old Jan 31, 2004 | 10:08 PM
ddmau's Avatar
ddmau
Well, that settles it...I'm not driving it anymore! :nonod:
Old Feb 1, 2004 | 09:18 AM
VetteTech81's Avatar
VetteTech81
Not with MOBILE 1, you could go 200K miles without anywear.. LoL :jester
Old Feb 1, 2004 | 11:35 AM
BillY2KFRC's Avatar
BillY2KFRC
If you use downshifting a slight assist in braking it won't hurt a thing. What could cause problems is if at every stop sign you shift to 2nd at 45mph to slow the car down... this I could see causing wear as you're shooting the motor up to 5000rpm to slow you down. But, within reason, it won't be a problem at all. Just use the brakes and motor to help each other, don't depend on just one.
As for rev-matching, it's a great thing to do, and really separates the good stick drives from the bad. But, it won't affect the wear on the motor, just the clutch/tranny.
Old Feb 1, 2004 | 12:58 PM
IFLUBYU's Avatar
IFLUBYU
I used to use downshifting quite a bit to slow down, heck I learned to drive stick in a tow-truck (hopefully my old boss from 23 years ago ain't reading this!). The real danger is down shifting into a gear and engaging at or above the max rev. The rev-limiter only cuts spark or fuel on the rev climb during acceleration to keep you from over-revving. If you down shift from 4th to 3rd, and accidently hit 1st (if you are not used to a six speed, it can happen), or anything similar the power is forced from the drivetrain back into the engine and can over rev the engine into some serious problems. The most common problem I have heard of, possibly experienced (still not sure it was a downshift that caused it) is over revving the valve train, floating a vavle and ending up with broken or bent push rods or worse. :cry
If a pro was mentioning it being dangerous, I would guess this would be what he was referring to. Been forcing myself to get out of the downshifting habit.
Hope that helps, good luck...
Old Feb 1, 2004 | 03:04 PM
maddog's Avatar
maddog
Default Re: Downshifting (IFLUBYU)
I downshift often since I added borlas, and I have gotten into a habit of bliping the throttle to downshift and match revs. I realize doing this is unnesessary, but does it hurt the engine more than just slowly engaging into gear? :lurk:
[Modified by maddog, 3:05 PM 2/1/2004]
Old Feb 1, 2004 | 05:26 PM
ddmau's Avatar
ddmau
No, I use each gear to slow the car and enjoy the pipes...I never get even close to the redline. :nono: Downshift with slight brake if necessary sounds about right to me. :steering: :seeya
Old Feb 1, 2004 | 06:01 PM
Darkness's Avatar
Darkness
It wont harm the engine as much as the tranny if you dont rev match or at least ease in the clutch to prevent sudden drivetrain jolt.
Old Feb 1, 2004 | 06:44 PM
Tree's Avatar
Tree
Default Re: Downshifting (Darkness)
If you're going to the trouble of matching revs, you might as well double clutch so that you also save wear on the synchros as well as being easy on the rest of the drive train.
Old Feb 1, 2004 | 08:14 PM
Darkness's Avatar
Darkness
Default Re: Downshifting (Tree)
Been hanging with ricers recently???;) Double clutching was only useful back when cars/trucks didnt have syncros. No need for that now unless you wanna loose time doing it.
Old Feb 1, 2004 | 10:49 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Your kidding!!! :p:
Old Feb 1, 2004 | 11:01 PM
KAH_BigRedCorvette's Avatar
KAH_BigRedCorvette
If I'm coming to a stop, I push in the clutch, shift to neutral and use the brakes as I pull to the light--no downshifting.
If I'm just slowing down and continuing to roll, I downshift and match revs as best as I can and keep rolling.
Works for me.
:steering:
Old Feb 2, 2004 | 08:18 AM
Tree's Avatar
Tree
1. I honestly don't understand the ricers reference.
2. Double clutching wasn't USEFUL when transmissions didn't have synchros, it was MANDATORY.
3. What does losing time have to do with this thread? It's not about racing. If it was, we wouldn't be talking about shifting to use engine compression to slow down.
Old Feb 2, 2004 | 08:25 AM
Automag928's Avatar
Automag928
Default Re: Downshifting (KAH_BigRedCorvette)
:withstupid: I rather replace brake pads than have to have tranny work done.
To Downshifting
Old Feb 2, 2004 | 11:01 AM
corvettedan22's Avatar
corvettedan22
Default Re: Downshifting (Automag928)
:iagree:
i down shift but tend to go a little heavier onthe brakes to keep wear and tear on the motor and trans to a minimal.
Old Feb 2, 2004 | 11:42 AM
bmathews's Avatar
bmathews
Doesn'y understand what a ricer is???? :conehead :troll
Old Feb 2, 2004 | 02:31 PM
Tree's Avatar
Tree
Default Re: Downshifting (bmathews)
Look Brian, I'm sure I'm not as smart as you (maybe I should be thankful), but I didn't say I don't understand what a ricer is. I said I don't understand the reference to it. The topic at issue involved downshifting and synchros, and I wondered why someone would make a ricer comment. By the way, welcome to the Forum. Hopefully you can wait another 9 days before making additional stupid comments.
