Brake question, silcone vs Dot 4?
Old Feb 1, 2004 | 05:41 PM
Corvettj's Avatar
Corvettj
Default Brake question, silcone vs Dot 4?
Getting ready to do the Baer rotors Hawk pads brake job, can I empty the system, with a power bleeder, then re-fill and use silcone Dot 5 fuild, will this work? or do I have to flush system before using silcone? and what would you flush it with>
Old Feb 1, 2004 | 06:45 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Brake question, silcone vs Dot 4? (Corvettj)
silicone??? do you mean synthetic??? dont use synthetic... one of the best brake fluids out there is Ford's Dot 4.. it has a 550 boiling point.. about 2.50 a pint. Many guys here on the forum use it
Old Feb 1, 2004 | 07:35 PM
vettenuts's Avatar
vettenuts
Default Re: Brake question, silcone vs Dot 4? (Evil-Twin)
Don't use silicone DOT 5 fluid. This is incompatible with the ABS system, and doesn't tolerate the pressure fluctuations that the ABS puts into the system. It will fall below vapor pressure and you will end up with bubbles in the system. Stick with a good DOT 4 fluid, I plan on using the "Blue Stuff" :yesnod:
Old Feb 1, 2004 | 08:09 PM
Darkness's Avatar
Darkness
Default Re: Brake question, silcone vs Dot 4? (vettenuts)
Yes, I heard the same thing on that. :iagree:
Old Feb 1, 2004 | 11:52 PM
corvette dave's Avatar
corvette dave
Default Re: Brake question, silcone vs Dot 4? (Darkness)
Synthetic is good.
Silicone is not.
To Brake question, silcone vs Dot 4?
