Meziere EWP
Old Feb 3, 2004 | 11:13 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Meziere EWP (2ndVette)
I understand what you are saying and with the water acting as an additional force the power required to run it is increased.
My point in this thread is... There are many other "better things" to do with our cars to get good HP out of a C5. Other than adding a $500 water pump for a few hp... (epecially when there is nothing wrong with the one in a car)... and then complain about how it dynoed at the same number or a few Hp more.
VR :cheers:
Old Feb 3, 2004 | 12:08 PM
marco383's Avatar
marco383
Default Re: Meziere EWP (vetterdstr)
Where did the "rebuild every two years" come from? Unless you drive 50k miles/year plus, that doesn't sound reasonable.
Old Feb 3, 2004 | 12:20 PM
Paul @ Thunder's Avatar
Paul @ Thunder
Default Re: Meziere EWP (Terry Burger)
The more gear and HP you already have, the more the pump will help.
Actually Terry it's just the opposite. The LESS HP and Torque you have the more the pump will help. Look at it this way:
The Force to turn the pump at a given RPM is a constant. Apply that constant to a motor making 1000ftlbs torque. Now apply that same constant to a motor make 20ftlbs torque. There will be significantly more percentage of loss on the lower torque motor. Where the higher torque motor may loose less then 1% the lower one in this case could lose 50% or more. Now I know this is an extreme example but the physics apply to any motor.
Thunder Racing did all of the R&D dyno testing for Meziere and we saw an average gain of 6-8rwhp on every car we tested, which we put the pump on 6 different cars. We never saw under 5 or over 10 on any car we tested, auto or standard. Most of the cars also had underdrive crank pulleys. Like someone stated earlier you are really buying the pump for cooling efficiency but a small gain in HP doesn't hurt either. :D
Old Feb 3, 2004 | 12:32 PM
Cobraeater's Avatar
Cobraeater
Default Re: Meziere EWP (Paul @ Thunder)
Paul, did you test all the cars with that prototype of the Meziere?
Since it looks like the regular production Meziere don't make hp.
Old Feb 3, 2004 | 12:33 PM
myblackC5's Avatar
myblackC5
Default Re: Meziere EWP (kumar75150)
after engine stops hot, don't the temp continue to rise? if you had a electric pump and some way to cycle it after shut down, could be an advantage. i know electric fans used to turn on a couple times after shut down. i could see and engine stoping hot at 190 deg then spiking to maybe 300 deg before it starts to cool down.
:chevy
Old Feb 3, 2004 | 12:34 PM
Cobraeater's Avatar
Cobraeater
Is there a trick to getting hp out of this damn thing?
I got exactly 0 hp out of it when I did it a few months ago. Today I saw a TA on the dyno make back to back pulls before/after the pump. It didnt gain 1 hp.
Actually, it dynoed 3hp higher w/o the pump although that is probably just the variance in the pulls.
I was the one who dynoed my car at MMT yesterday with back-to-back before/after pulls with the Meziere and saw a zero hp gain.
BTW my car was a Camaro SS not a T/A! :p:
Old Feb 3, 2004 | 12:54 PM
Paul @ Thunder
Default Re: Meziere EWP (Cobraeater)
4 of the cars were tested with 2 different preproduction units. 2 additional cars were tested with a pump from our first stocking order. We did one on a 370cid motor about 3 weeks ago and it made 7rwhp. I'm not sure how other people are dynoing the cars. When you are measureing horsepower with such a small difference it is VERY critical that coolant temp, air intake temp, and oil temp are near identical. If not your number will be inaccurate.
Paul
Old Feb 3, 2004 | 01:25 PM
V8_Club's Avatar
V8_Club
Default Re: Meziere EWP (marco383)
Like I said on Average, I recall reading earlier that it was recommended to buildup after x hours of usage. Anyway by using an average number of hours daily use & multiplying it by 30 then dividing by the X the number was close to around 2 years. ( Can't remember the number :banghead: ) But seeing that it is under warranty for 2 years means that I'm not off by a lot. Again I meant on Average. Here is some food for thought, since its prime benefit like all of the above seem to agree is not Hp but Cooling isn't a higher effeciency radiator a more reasonable purcahse for the $$$ ? Given it costs more or less the same & will be with fewer hassles. :steering:
[Modified by V8_Club, 10:27 PM 2/3/2004]
Old Feb 3, 2004 | 06:14 PM
kumar75150's Avatar
kumar75150
Sorry I never went out back to look. :cool:
