Does the Blackwing throw codes???????
Old Feb 2, 2004 | 11:27 PM
dogdoc97's Avatar
dogdoc97
Default Does the Blackwing throw codes???????
Will adding any of the intake mods cause me to get codes; blackwing,vararam,vortex, etc, thanks, Dogdoc :confused:
[Modified by dogdoc97, 4:28 AM 2/3/2004]
Old Feb 2, 2004 | 11:53 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Does the Blackwing throw codes??????? (dogdoc97)
Properly installed, no, no air filter upgrade should throw codes or cause problems.
If you do get any codes, the likely cuplrit would be loose airbridge connections between the MAF sensor and throttle body. Any air leak downstream of the MAF can cause lean codes.
:cheers:
Old Feb 3, 2004 | 12:22 AM
LivinTheDream's Avatar
LivinTheDream
Default Re: Does the Blackwing throw codes??????? (Y2Kvert4me)
:iagree:
Just make sure you seal everything back up properly and you will be fine.
Old Feb 3, 2004 | 07:24 AM
Thunder7's Avatar
Thunder7
:iagree: I installed mine without any problems, and have never seen a code.
Old Feb 3, 2004 | 07:37 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Nope... :yesnod:
Old Feb 3, 2004 | 08:52 AM
IMQUIK's Avatar
IMQUIK
It will throw an E code on the fuel tank :lol: EMPTY! Fill me up. :yesnod:
Old Feb 3, 2004 | 05:31 PM
texasredc8's Avatar
texasredc8
No codes with my Blackwing. Not re-connecting the MAF connector or one of the rubber couplings improperly installed could cause problems. Over-oiling the filter might also throw a code from the residue on the small wires in the MAF.
Old Feb 3, 2004 | 05:42 PM
joe03z06's Avatar
joe03z06
Default Re: Does the Blackwing throw codes??????? (TexasRedZ06)
no codes here
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
A few members have reported codes with a blackwing... These cars are weird... what works on one does not work on all.
VR :cheers:
Old Feb 3, 2004 | 06:06 PM
lowdowndirty's Avatar
lowdowndirty
:thumbs:
Old Feb 3, 2004 | 06:09 PM
JasonFRC's Avatar
JasonFRC
Default Re: Does the Blackwing throw codes??????? (lowdowndirty)
Yup. I installed mine a week ago. Make sure the MAF sensor connector and the temp sensor wire are seated correctly. It's easy to leave one partially loose. :thumbs:
To Does the Blackwing throw codes???????
