How hard is rear end change.
Old Feb 3, 2004 | 10:06 PM
blackbelt's Avatar
blackbelt
Default How hard is rear end change.
It should becoming in this week from ecs and we are doing heads and cam swap this weekend so we figured on doing it to is it very difficult or should i just pay someone to do it? Any how to's? or tech tips?
Old Feb 3, 2004 | 11:12 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: How hard is rear end change. (blackbelt)
:lurk:
Old Feb 3, 2004 | 11:21 PM
jmzvet's Avatar
jmzvet
I've done 2 swaps using MikeMercury's instructions found here on the Forum. Time consuming but not difficult. If you can do a H/C swap you can change out a rear diff. no problem :cheers: .
Old Feb 4, 2004 | 07:30 AM
spdy's Avatar
spdy
Here's a link from my fairly recent post. http://forums.corvetteforum.com/zerothread?id=737658
Haven't done it yet, as I haven't recieved my gear set. I'd be interested in your results/lessons if you do it. :cheers:
Old Feb 4, 2004 | 09:15 PM
pdd000's Avatar
pdd000
Default Re: How hard is rear end change. (spdy)
i just swapped my clutch and rear end on jack stands. not too bad to the do the rear end, but i had sum fun with the clutch :smash:
To How hard is rear end change.
