Help Keyless entry problems
Old Feb 6, 2004 | 11:13 PM
damenke's Avatar
damenke
Default Help Keyless entry problems
My remote keyless entry doesn't work all the time. I've got a 2000 Vert. Did the matching transmitter, resynchronized, replaced battery. Still only works off and on. Never know when its going to work. Anyone had this problem?
Doug
Old Feb 7, 2004 | 01:20 AM
texasredc8's Avatar
texasredc8
Default Re: Help Keyless entry problems (damenke)
Did you just get the car, or have you had it a while and this problem just started after a few years of ownership??
Do you have another key fob to operate for a while to see if its the transmitter or the receiver problem??
I had a 2000 Coupe, and you had to be within 5 feet of the driver's door, or it wouldn't work. So, are you trying to use the system at a distance beyond 5 feet or from the passenger side??
Old Feb 7, 2004 | 09:49 AM
ROD BROWN's Avatar
ROD BROWN
Try taking the battery out of the opener and clean the contacts with the eraser on a lead pencil.The contacts may be dirty.Worth a try.My door opener had to be replaced.(1) worked perfectly,the other took a dump.They aren't cheap,mine ran $105 at the agency. :chevy :chevy :flag :chevy :chevy
Old Feb 7, 2004 | 11:13 AM
Soldiervette's Avatar
Soldiervette
I had same problem...
i disconect the battery on the car it self and the battery of the fog and clean the contacts with TUNER "electrical contact cleaner" sold in ....Radio Shack and buy new battery for the fob...then go ahead and conect car battery and reprogram fob.. i did all this and i havent get any more troubles since ... GL
To Help Keyless entry problems
