What is pcm code P-0410 represent?
Old Feb 8, 2004 | 12:36 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default What is pcm code P-0410 represent?
Just popped up on my z06 after sitting in a cold garage (30 degrees) for three weeks and never threw this code before. Could it be related to sitting in the cold without being started for 3 weeks?
THANKS!!! :cheers:
[Modified by MTI 427 Roadster, 11:36 AM 2/8/2004]
Old Feb 8, 2004 | 12:45 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: What is pcm code P-0410 represent? (MTI 427 Roadster)
P0410 AIR System
whatever that means http://www.97vette.com/howto/codes/index.html
[Modified by pewter99, 12:45 PM 2/8/2004]
Old Feb 8, 2004 | 01:27 PM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
From the GM manual, "During the AIR test the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the H02S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the H02S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative."
Did any other codes set?
Hope this helps.
Old Feb 8, 2004 | 01:28 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Reset the code and see if it comes back :cheers:
Old Feb 8, 2004 | 01:57 PM
Mopar Jimmy
St. Jude Donor '06
Default Re: What is pcm code P-0410 represent? (runamuk)
THANKS GENTLEMAN!!!! :cheers:
To What is pcm code P-0410 represent?
