Stroker???
Old Feb 9, 2004 | 09:09 PM
Bone_Stock's Avatar
Bone_Stock
Default Stroker???
Which vendor makes the best 382 stroker kit as far as quality and price? I haven't narrowed down which kit I want to go with yet. I see that Eagle is by far cheaper but how is the quality. Also Lunati is there with them, just a little more expensive. And I'm not sure if I should go with a LS6 block or if it's just a waste of money. Any info that would send me in the right direction would be greatly appreciated.
Old Feb 9, 2004 | 10:40 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Stroker??? (Bone_Stock)
I would take some time to call around and see what the vendors recommend and check on some pricing. :seeya
Old Feb 9, 2004 | 10:48 PM
Bone_Stock's Avatar
Bone_Stock
Default Re: Stroker??? (CHRIS NJ C5)
That's why I posted this thread... to get your opinions :cheers:
Old Feb 9, 2004 | 10:51 PM
kumar75150's Avatar
kumar75150
AP Engineering has some good deals using the Eagle stuff.
Old Feb 10, 2004 | 08:03 AM
vstella's Avatar
vstella
I can't complain about my Lunati 382...Just "tons" of torque!! In fact TBYRNE now has a sale on ALL Lunati kits and cams... :yesnod:
Videos and pics of my 382 Lunati LS1 on my CF homepage...link below :D
Old Feb 10, 2004 | 01:15 PM
Brian@ap-engineering's Avatar
Default Re: Stroker??? (vstella)
When the cranks are ready , we are selling them for 2500 balanced.
These kits will include:
Eagle 4.000 stroker crank
Eagle H beam rods
Diamond shelf pistons w/ pins
Diamond Proselect ring set
Federal Mogul main bearings
Clevite rod bearings
Please call if you have questions
Old Feb 10, 2004 | 11:45 PM
COLORADO FRC's Avatar
COLORADO FRC
[QUOTE]I can't complain about my Lunati 382...Just "tons" of torque!! In fact TBYRNE now has a sale on ALL Lunati kits and cams... :yesnod:
I purchased my Lunati kit from TBYRNE, they were great to work with. Because I'm building my motor for a Vortech T-trim SC, and live in Colorado (high altitude), they were able to determine which pistons I needed to achieve the compression ratio I wanted, and in my case, at no extra charge :). The Lunati kits are also known to balance out much better than some of the less expensive kits.
Old Feb 11, 2004 | 08:14 AM
Default Re: Stroker??? (COLORADO FRC)
I have a complete Callies kit as well :
Callies forged crankshaft
Callies 6.125" forged rods (LS1 specific, on center)
Diamond shelf pistons (flat tops or dishs)
Diamond Proselect rings (file fit)
Diamond wrist pins
Balanced
Total - $3699.00
Old Feb 11, 2004 | 08:57 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Stroker??? (Brian@ap-engineering)
Are you planning to build the motor yourself or have a shop build it?
From what I've read Speed Demon and AP have the best deals going on kits.
Old Feb 11, 2004 | 11:01 AM
speedjohnson's Avatar
speedjohnson
Default Re: Stroker??? (93Polo)
Gene at Karshop has a stock of new GM LS6 blocks complete with caps, bolts and cam bearings for something like $625.00 + shipping.
The LS6 blocks have a better ventalated crankcase. I've also heard that the block is butressed a little more for strength...but not sure on that.
You can't go too far wrong with this kinda deal. I've had excellent dealings with this vendor in the past and my new block is now awaiting a stroker assy.
I think that the eagle stuff might be OK for a street application...I'm not sure what machining/lightening is done to the foriegn made steel forgings or how deep the nitriting is.
I run the Lunati pro-mod stuff in by race car and have had no issues. The cranks are a good american steel forging. They are nitrited to a good depth. The crank throws are lightened and knife edged.
The pro-mod rods are nice cap screw "stroker profiled" forged I-beams so there is no issues with clearance. They are also alot lighter than most other rods in this "quality level" so the rotating assy can often be balanced without using mallory metal.
I don't know anything about Lunati's pistons...I've always used JE. However, you might want to check to see if they're forged or hyperutectic. The forged are stronger, but need more clearance and tend to "rattle" a bit until the engine is warmed up. The hyperutectic are more brittle but can be fit tighter in the bore. In a street car, the added strength might be an issue if you're using spray. Also ask about the depth of the valve pockets if you're going to use a big cam.
Good luck with your parts selection. Keep us apprised on your project!
Old Feb 11, 2004 | 11:22 AM
Automag928's Avatar
Automag928
:lurk: I have a friend who ordered a motor from AP engineering. Waiting to see the results, hopefully should be done soon, but everything I have heard about them has been excellent. Also check LS1tech.com for more opinions.
Old Feb 11, 2004 | 09:59 PM
Default Re: Stroker??? (Automag928)
The Lunati and Callies stuff is first rate pieces. It comes down to this: Is the Eagle stuff 1000 hp pieces? Never. 850? Maybee. 600 ? Every day of the week. If the eagle parts that are being made today keep the same quality level that we have seen so far, i think they will suit 99 % of everyone on this board.
And you are correct again in stating that the higher priced stuff balences easier.
Old Feb 11, 2004 | 10:56 PM
Bone_Stock's Avatar
Bone_Stock
Which is recommended:
Lunati or Callies
Old Feb 12, 2004 | 10:52 AM
COLORADO FRC
I went with Lunati, but mainly because my engine builder has a lot more experience with their parts and has never had issues with them. He also said he had heard that the Callies parts were good as well, but had never used them himself. He has also built allot of engines using the Eagle parts in order to save some cost, also with no issues other than balancing was more difficult. My application should produce 600- 650 RWHP, I wanted the piece of mind and Lunati won out.
Old Feb 12, 2004 | 11:54 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
All i can say is that my brand new CALLIES 4.125 crank's welds broke as well as the reluctor wheel after only 2500 miles!!! :U :mad :boxing :banghead:
That's why i'm now running a lunati LS1 crank and that is all i will EVER RUN from hear on out!!! :chevy :steering:
Old Feb 13, 2004 | 11:19 AM
FreddyG's Avatar
FreddyG
Why go with a 382? Check this post, the price is GREAT, and the builder use to work for Katech (they build the C5R motors).
http://forums.corvetteforum.com/zerothread?id=752270
To Stroker???
