ALIGNMENT IN N.VA
Old Feb 10, 2004 | 01:20 PM
Sihler's Avatar
Sihler
Default ALIGNMENT IN N.VA
where can I get my lowered '97 aligned in the northern virginia area. Also, I would like to have an LS1 edit done, if anyone knows, that would be great.
thanks.
Old Feb 10, 2004 | 02:55 PM
YELLOHHH's Avatar
YELLOHHH
Default Re: ALIGNMENT IN N.VA (Sihler)
Tony's Corvette Shop in Gaithersburg MD. (301)987-0565. For sure on the alignment, not sure on the LS1 edit. I know they are supposed to be getting it, but not sure if they do yet or not.
Old Feb 10, 2004 | 03:02 PM
Sihler's Avatar
Sihler
Default Re: ALIGNMENT IN N.VA (YELLOHHH)
THANK YOU :thumbs:
Old Feb 10, 2004 | 04:02 PM
IFLUBYU's Avatar
IFLUBYU
Tony's always does good work. There is also Curry's auto service right here in Ashburn, just a couple of minutes up the road from Herndon. They were a little pricey at $260 but they did do it right. As far as LS1 Edit goes, no real pro in the area for that one that I know of, and I have looked. I take mine up to TheVetteDoctors for that. Bit of a hike but worth it...
Good luck! :thumbs:
Just to clarify, that was for a four wheel alignment.
[Modified by IFLUBYU, 4:03 PM 2/10/2004]
Old Feb 10, 2004 | 04:20 PM
RyanC7's Avatar
RyanC7
Default Re: ALIGNMENT IN N.VA (IFLUBYU)
http://www.woodbridgedynotech.com for LS1 edit.
Old Feb 10, 2004 | 06:12 PM
Sihler's Avatar
Sihler
Default Re: ALIGNMENT IN N.VA (Ryan2002C5)
I talked to Tony's, they are supposed to get back to me on a price. They say they will be able to do an LS1 edit soon. Thanks again, guys.
Old Feb 10, 2004 | 09:23 PM
David Plum's Avatar
David Plum
Alignment sterling craven tire has latest hunter aligner road force balance nitrogen tire fill station great front end guy see Ron Jones he is the man!!
Old Feb 10, 2004 | 10:30 PM
mowrey96's Avatar
mowrey96
Once you use Tony's, you will not want to take it anywhere else. :cheers:
Old Feb 10, 2004 | 11:01 PM
bigsteff's Avatar
bigsteff
Default Re: ALIGNMENT IN N.VA (mowrey96)
:iagree:
To ALIGNMENT IN N.VA
