3k to spend...
Old Feb 11, 2004 | 11:25 PM
Sorny's Avatar
Sorny
Default 3k to spend...
Hey all,
I'm expecting a $3k check from uncle sam, and think this would be a great opportunity to add some go-fast goodies to my new car (had her one week).
What would you guru's suggest for a bone stock '00 FRC as far as first mods go? Keep in mind I'm wanting to stay NA, so no FI stuff. The eventual goal is to go with new heads/cam, maybe stroke it, but I figure I should exhaust the bolt-ons first. ;)
I was thinking of something like a Blackwing, some long tube headers, and x-pipe, maybe a cat-back (not sure if they actually make more power, I'd appreciate feedback; I don't care about how it sounds, other than anything obnoxiously loud is out of the question). My budget is pretty firm at just over $3k, and labor would have to be included (likely going to XMSEngineering in Tempe, since they are a local vette shop).
Thanks in advance for your thoughts,
Sorny
Old Feb 12, 2004 | 01:10 AM
Jimmy Smits's Avatar
Jimmy Smits
Default Re: 3k to spend... (Sorny)
Easy enough. 1st get 4.10 gears, biggest bang for the buck and you will see the best results (besides nitrous of course). A set with hardened shafts will run you about $1300. Install will be $400. That leaves enough for a Blackwing (install it yourself, it only takes 20 minutes), shifter, and headers (if you install yourself). With those mods, you'll have an easy low 12 sec car, then you can start saving for tires. :smash: :cheers:
Definately get the gears, I love mine so much, and so does everyone who gets them (read up on them). Other than my nitrous system, gears were the best money I spent on mods. Enjoy!
Old Feb 12, 2004 | 01:26 AM
Cary's Avatar
Cary
I understand labor cost is a factor, since you mentioned a shop would be doing the installs. Do they have a dyno & LS1 Edit capability? If so, IMHO get a baseline dyno# and if you decide on some long tube headers an LS1 Edit tuning is not required but very helpful. The Pro LG LT Headers system is best RWHP/RWTQ money can buy.
Do you have an auto or stick tranny? An A4 w/2.73 needs to be replaced with a 3.42 rear diff, IMHO. If you have a stick w/3.42 factory rear, then step up to at least 3.73 or even 4.10 gears.
Take a look at some of the CF SIGs or check out My Homepage
http://www.cardomain.com/memberpage/326343/1 for mod ideas.
Good luck,
[Modified by Cary, 12:29 AM 2/12/2004]
Old Feb 12, 2004 | 02:17 AM
Jimmy Smits
Default Re: 3k to spend... (Cary)
Do you have an auto or stick tranny? An A4 w/2.73 needs to be replaced with a 3.42 rear diff, IMHO. If you have a stick w/3.42 factory rear, then step up to at least 3.73 or even 4.10 gears.[Modified by Cary, 12:29 AM 2/12/2004]
All hardtops are 6 speeds.
Old Feb 12, 2004 | 02:39 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: 3k to spend... (Jimmy Smits)
:thumbs:
Old Feb 12, 2004 | 10:08 AM
BayouVette's Avatar
BayouVette
Default Re: 3k to spend... (LittleBoyBlu99)
I would check the boards for a H/C package. You can find some real good ones for 2k.. I know right now Corvette Poor is selling a Cartek stage 2 h/c package for 2k. Install and get tune.. you should be right around the 3k mark.
Old Feb 12, 2004 | 10:19 AM
Sorny's Avatar
Sorny
Default Re: 3k to spend... (BayouVette)
Won't stock intake/exhaust severely choke new heads and a cam?
Old Feb 12, 2004 | 10:33 AM
COLORADO FRC's Avatar
COLORADO FRC
Heads, cam and FLP's took my '99 FRC from 319 RWHP to 393 RWHP (no tuning). I went with A & A's stage II heads and a 220 220 cam from Andy as well. Although I haven't had any experience with them, I've also heard the Patriot Heads may be the best deal as far as price and performance goes.
Old Feb 12, 2004 | 10:34 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
For 3k I would do the following
LG Headers 1500
Whichever exhaust system you like - around 550
Intake - - Halltech - Blackwing - Vararam- Halltech and Vararam are more expensive 500 vs about 250 for the blackwing.
So you are right around 3000 with install and tunining. You will get an honest 30+ rwhp with those parts and your car will be running great.
Good Luck with your car, and get ready for the mod bug to bite. Once you start it will never end
:D :D :D
[Modified by Ruby6spd, 10:36 AM 2/12/2004]
[Modified by Ruby6spd, 10:37 AM 2/12/2004]
Old Feb 12, 2004 | 10:42 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: 3k to spend... (Ruby6spd)
gears, vararam, and juice... :thumbs:
Old Feb 12, 2004 | 11:08 AM
fairway's Avatar
fairway
I would check the C/5 for sale section for used heads/ cam or do a cam only thats about 1700 to 1900 and headers or gears :auto:
Old Feb 12, 2004 | 11:48 AM
MC TORCH RED
Default Re: 3k to spend... (fairway)
:iagree: :thumbs:
Old Feb 12, 2004 | 01:56 PM
Jimmy Smits
LG Headers 1500
Do all of that, and still get smoked by every 4.10 equiped vette on the road. There is no replacement for gearing (besides nitrous and FI). :smash: :smash:
Old Feb 12, 2004 | 02:57 PM
Terry Burger's Avatar
Terry Burger
I'm not so sure gears really make the car that much faster, they might just make it "feel" faster. ;) Anyone have solid back to back track results 3.42s vs. 4.10s, stock motor, all else being equal?
Old Feb 12, 2004 | 03:06 PM
00TORCHCOUPE's Avatar
00TORCHCOUPE
Default Re: 3k to spend... (Terry Burger)
I don't think you can get anything done worth while. :nonod: Just give the money to me and I will take care of it for you! :lol:
Old Feb 12, 2004 | 08:32 PM
Jimmy Smits
Gears make you accelerate faster, thus lowering your ET. I knocked .5 off my ET with the gear swap, not to mention countless street races won. It's all about getting out of the hole fast (in racing...lol).
Old Feb 12, 2004 | 09:03 PM
Cary's Avatar
Cary
:bb My bad :bb Anyway, step up to at least a 3.73 or even 4.10 rear diff :yesnod:
Old Feb 12, 2004 | 09:44 PM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
Headers, Cam, Then Vararam...
Vararam Rules... The G5-X2 Cam rocks... The G5-X3 cam is Awsome too... And the LGM Headers are the best on earth... literally...
Build cost tally...
Cam - 900 from LGM
Headers - 1800 from LGM
Vararam - 300 from WCC
110 more HP for under 3000 - Priceless
To 3k to spend...
