Tire sensors computer programmer needed
Old Feb 13, 2004 | 08:50 PM
RD3721's Avatar
RD3721
Default Tire sensors computer programmer needed
I would like to be able to switch back and forth with two complete sets of tires and wheels for my '99 C5. I have purchased a set of Z06 wheels and tires that I want to use at the track from time to time. I also will be using my stock chrome wheels / tires on the street most of the time. I'm told that the sensors will have to be programmed ever time I make the change. If this is true, Is there a Power programmer out there that will allow me to program the computer for this issue when changed around?
Thanks for any info on this,
Bob :cheers:
Old Feb 13, 2004 | 09:06 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Tire sensors computer programmer needed (RD3721)
You don't need any programmer to train the pressure sensors. All you need is a magnet and these instructions; https://www.corvetteforum.com/techti...D=77&TopicID=1
If you are only bolting on wheels for the track, I would not bother programming them for a day, or even installing sensors in them. You might get a "service tire mon. sys." error message on the DIC when using those wheels, but all you need to do is hit reset and go race. It will not cut power or anything like that.
When you put your street tires back on, everything will be back to normal and the readings will resume with no programming.
:cheers:
Old Feb 13, 2004 | 09:09 PM
IFLUBYU's Avatar
IFLUBYU
If you switch to different tires with different sensors, they will have to be re-synchronized with the car, but it does not require a programmer. You just have to re-train on the new sensors. There is a procedure for this in the archives somewhere, but here is the short of it (someone chime in if I forget something):
Tools required:
Key to your car
Magnet (I use my craftsman magnetic retrieval tool, saves you from bending over too)
With engine off, turn the key to the ON position
Press the "Options" button on the dash until it goes to the blank spot
Press and hold reset for 3-5 seconds
The DIC will display "FOB" training, (heres where I cant remember if you let it time out, or if you hit reset to continue, anyone?)
Next will be "Pressure Sensor Training" (or something like that)
Press Reset to begin, or maybe it just starts it after a couple of seconds(I can never remember)
Now take your magnet and go to the Front-Driver-Side wheel, and hold the magnet (gently lest you scratch) the wheel to just one side of the valve stem wait 3-5 seconds and the car should HONK and flash lights. If this doesnt happen move the magnet to the other side of the valve stem and wait 3-5 again. Move clockwise around the car Front -Pass, Rear-Pass, Rear Driver, and repeat. You have to get them all in one set for them to take.
If one will not train, double check the DIC to make sure it didnt exit out of the training mode. If it still wont program, you probably have a bad sensor. You will still be able to read pressure off the ones programmed before it in the rotation.
Hope that helps, good luck! :thumbs:
D'oh, guess I took too long typing, y2kvert4me beat me to it!
[Modified by IFLUBYU, 9:10 PM 2/13/2004]
To Tire sensors computer programmer needed
