Best suspension setup for rough street cornering?
I have to ask this question since I was not closing on one of those new BMW minis on a rough surface cloverleaf onramp. He started off 50' ahead and stayed there, meaning he hit the throttle at exit 50' earlier. By the time I caught up he was doing 80mph, I had to hit 90mph to do it. Not a bright way to avoid tickets, but I couldn't let a Mini get away from a 700hp Corvette...
And to think I was considering drag radials.
[Modified by blu00rdstr, 1:29 PM 2/16/2004]
My Coupe is stock but I've felt a bit unstable on rough roads too. From my research, coil overs are the way to go. When I get mine installed in 2-3 weeks, I'll know that if they are what they say they are...
I have an 02 and I get the same feeling unless the road is prefectly smooth.
My concern on street use, is that the T1 bars may not give much warning before one of the ends of the car break loose.
Your Supertire tires offer very good dry traction on the street. It would probably be wise to accept the fact that a lighter/lower powered car could be more suitable for rough pavement and even faster that a 700 HP Corvette through a rough pavement corner. It's just the design of the beast. :cool:
Jim
My confidence in the grip, partially because it felt skippy on the bumps.
Just kidding. I am running '04 Z shocks/springs along with the T1's and am still considering on going back to the Z51 shocks for more stiffness. The shocks definitely soften up the bumps and I know the T1's will hold the turns. I'm just not so sure that the 345's are holding as well as the runcraps though.
I would say your biggest problem is going to be getting used to the extra power you have. If you don't just barely feather the gas pedal the sudden rush of power from your SC'd powerplant may be unsettling your ride.
That's all I can think of.
Go get those Minis! :auto: :lolg:
What I'd recommend considering is taking a class in High Performance driving, rather than spending more money on suspension changes. Even straight stock, the Corvette suspension has WAY more capability than most drivers know how to use.
For example, first time I took a HP Driving class was at Sears Point Raceway. In one session, I'm coming down through the "Carousel", a sweeping left turn that drops down a hillside as you turn through about 180 degrees. As I'm approaching the bottom of the hill I see in my mirror a BMW rapidly catching me. Now I'm going about as fast as I think I can, and he has a good 10 mph advantage over me. So I figure maybe he's got big suspension mods, but I found out later he was running stock set-up.
Bottom line, he was a driver that knew the corner and how to handle his car. Over time I've gotten much faster, but the main thing I've learned from the schools is that outside of true professional race drivers, your skill level is going to be the biggest factor in cornering speed, not your suspension set up.
Finally, suspension set up is a compromise when you are driving on the street. For a particular track, you can choose the "appropriate" spring rates, shock rates, anti-roll bar stiffness, etc. knowing how smooth/rough the asphalt is, whether there are bumps in certain corners, whatever. For the street, you want a suspension set up to give you great handling on bumpless corners, great handling on bumpy corners, and still provide acceptable levels of compliance for cruising. Not an easy job, and the Chevy engineers actually did it pretty well with the stock set up. As you mod your suspension, you are basically adding capabilities in one area (such as stiffening roll resistance by going to heavier anti-roll bars making you faster in smooth corners) while loosing capabilities in another area (that stiffer bar will detract from tire adhesion in bumpy corners). Ain't life a wonderful thing ?? :D
Steve
Years ago I had a Fiat 124 coupe. The suspension was very soft so I put Addco anti-roll bars on it, but left the springs and shocks stock. This gave flat cornering while still retaining most of the travel and compliance (much more travel + softer than my C5). We have a downhill road around here that has a flat ski-jump like area. I could come down that road in the Fiat so fast that it would get about 18 inches airborn! And never bottom out on the landing! Try that in a C5! :nonod:
All suspensions are compromises. No matter what you do to your Corvette suspension it will never be the fastest on ALL road surfaces. My advice? Choose your races wisely and you will never get beaten! ;)
TT :cheers:
Steve
The mini (slalom performer) probably knew he was good for that corner speed from experience. I glance at my HUD to reinforce my lack of brass, telling myself "I've done this corner at this speed before"...Experience in a particular corner is usually better than trying to read the limits real-time, at least for this amatuer, because when it does skip a bit, so does the heart!
Like the BMW referenced above on the track, I held off my buddy's C4 on my daily twisty mtn road with a Mazda 323, by knowing the limits of the car and the course.
Check out recent Road and Track's tale of Dan Gurney preferring mini-vans for humbling unsuspecting drivers in superior rides.
[Modified by Paras, 8:56 AM 2/18/2004]
