Coolant- How often to change
Old Feb 16, 2004 | 04:39 AM
BostonJoel's Avatar
BostonJoel
Default Coolant- How often to change
How often should the engine coolant on the C5 be changed?????
Old Feb 16, 2004 | 06:59 AM
vettenuts's Avatar
vettenuts
Default Re: Coolant- How often to change (Joel Forman)
They say 100K, but if you are running a 99 I would do it this year. Make sure you use the Texaco Dexcool, not the Prestone. Last I knew, Prestone didn't meet GM specifications. You can get it pretty cheap at Wal Mart. Also, you can get distilled water there for $0.58 per gallon to mix with the Dexcool and use for the flush.
Old Feb 16, 2004 | 08:13 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: Coolant- How often to change (vettenuts)
________________________________________ ________________________
:iagree: I changed mine on my 98 coupe after 76,000 miles. Remember.....Dexcool and distilled water.
Old Feb 16, 2004 | 08:26 AM
Fast98's Avatar
Fast98
Default Re: Coolant- How often to change (vette#one)
I changed my 98s at about 40,000 :chevy
Old Feb 16, 2004 | 09:38 AM
Oldvetter's Avatar
Oldvetter
According to owner's manual you should do it at 5 years or 150,000 miles whichever comes first. I changed my 98 C5 out at 5 years. Coolant was so clean, that I didn't even flush. Shop manual says if coolant is clean you don't need to flush. I drained out within 1 1/2 quarts of capacity anyway.
[Modified by Oldvetter, 9:38 AM 2/16/2004]
Old Feb 16, 2004 | 02:28 PM
TheBigGuy's Avatar
TheBigGuy
Default Re: Coolant- How often to change (Oldvetter)
Ditto on Blue Thunder. I changed at 50,000, clean and clear, so I did not flush. Drain slowly so you get most of it out. I got all but about 1 1/2 qts. out. Use only Texaco and distilled water. Good Luck ! :cheers: :chevy :seeya
To Coolant- How often to change
