Error Code Help
I checked the codes the computer was throwing and one thing that really bothers me is that the RDCM (right door control module) says "NO COMM" so I'm hoping this is the source of lots of codes being thrown.
28 TCS U1301H, C1255H, U1016H
40 BCM U1255H, U1016H, U1096H
58 SDM U1301H
60 IPC No Codes
80 Radio No Codes
99 HVAC No Codes
A0 LDCM B2252H, B2282H, B2284H, U1064H, U1016H
A1 RDCM NO COMM ???? :confused:
A6 SCM B2860H, U1300H, U1255H, U1160H, U1016H, U1064H
B0 RFA U1255H, U1096H, U1064H, U1016H
Any help would be greatly appreciated. I'm at work and have the 3 vol set repair manuals but they're at home.
:confused:
EDIT http://forums.corvetteforum.com/zerothread?id=753993 <- Original Post
[Modified by noelc5, 9:09 AM 2/16/2004]
Although you seem to have a lot of history codes, you have NO active codes, so I wouldn't worry about it.
You can reset all your history codes by disconnecting the battery for 2-5 minutes. But make sure you have security code for your radio, because it will lockup. You may also lose memory seat/mirror/radio/key fob settings.
[Modified by Oldvetter, 9:25 AM 2/16/2004]
I'm a college kid and the only way I have to wash my car is taking it to one of those pressure wash type deals. I sprayed the bajesus outta my car tryin' to clean it up for valentine's day. Is it possible I got water inside and screwed up the passenger door.
Thanks!
Thanks!
Make sure the RDCM is reporting, if it still says NO Comm then either your wiring harness is loose or disconnected somehow. :cheers:
My passenger door is real bad about leaking. I think this is the culprit.
Any other ideas, keep 'em coming!
Thanks!
