Cam vs Headers
Old Feb 17, 2004 | 05:22 PM
Rays Vet's Avatar
Rays Vet
Default Cam vs Headers
I was reading the post of a fellow modoholic and I am tossed between headers or cam first. If I remember correctly some one on here posted a tr220 cam I think that put out 40 hp from a cam only install versus headers
being in the vacinity of 20 to35 tops. Dollar for dollar the cam seems like the better choice for 1000.00 or less complete with install(maybe a little over) where as a good quality header at this reading is 9xx.xx not including install.
Any input on this and why you choosed the one you did???? see sig . car is still relatively stock.
Old Feb 17, 2004 | 05:27 PM
C5 CU's Avatar
C5 CU
Default Re: Cam vs Headers (Rays Vet)
problem with cam and stock exhaust manifold is cam will not perform up to expectation...expect only about 20rwhp from cam without headers...but when you do add the LT headers then get hp from cam plus the lost hp from cam running thru stock exhaust....
Old Feb 17, 2004 | 05:32 PM
hogurt's Avatar
hogurt
Default Re: Cam vs Headers (C5 CU)
You will get better results from the cam and no headers INSTEAD of Headers and no cam.
Of course, the real downside = more labor $ and you are now into the engine! Headers are a real bolt-on upgrade.
FWIW :cheers:
Old Feb 17, 2004 | 05:36 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Cam vs Headers (hogurt)
FWIW :cheers:
:iagree: If you can " do both. :thumbs:
Old Feb 17, 2004 | 06:41 PM
ddv005's Avatar
ddv005
Headers will accent all mods you do in the future ( no matter weather you go N/A or superchargered, Nitrous, etc..) A cam depends on weather you have heads, What stage, compression, N/A, Superchargerd, etc.....
So I would say do headers first, Do cam WITH the heads unless you only plan to do the headers and cam :party:
Old Feb 17, 2004 | 06:42 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
:iagree:
Old Feb 17, 2004 | 07:30 PM
camiv's Avatar
camiv
problem with cam and stock exhaust manifold is cam will not perform up to expectation...expect only about 20rwhp from cam without headers...but when you do add the LT headers then get hp from cam plus the lost hp from cam running thru stock exhaust.... :iagree:
Old Feb 17, 2004 | 07:35 PM
BlkThunder's Avatar
BlkThunder
Default Re: Cam vs Headers (Mr. Big)
I say it depends on what you want to do. If you are really looking to get as much horsepower as possible or you want to run it at the strip, then you will have to do both eventually. If you just want a little more kick in your seat than do the cam. Dollar for dollar its better. I have talked to many people that did a 220 cam only and got 40rwhp with a tune. I have yet to see any headers put that sort of power out. Personally I feel better spending the money on the cam. $1500 on pieces of metal is absurd. It should tell you something that a cam plus install, which requires you to get into the engine, costs the same as a set of headers, not installed.
Old Feb 17, 2004 | 10:50 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Cam vs Headers (ddv005)
I would go with a cam first if you plan on doing headers in the future. If you are only planning one or two mods then I would do the headers and leave the motor alone. A cam makes the car sound so much better. Good luck with your decision. Kaley
Old Feb 18, 2004 | 12:03 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Cam vs Headers (2C5only21)
:iagree:
Old Feb 18, 2004 | 12:15 AM
LittleBoyBlu99
Default Re: Cam vs Headers (BlkThunder)
:iagree: :cool:
Old Feb 18, 2004 | 01:57 AM
Mitch C's Avatar
Mitch C
:iagree:
Old Feb 18, 2004 | 01:59 AM
MC TORCH RED
Default Re: Cam vs Headers (Mitch C)
;) :yesnod:
Old Feb 18, 2004 | 07:08 AM
Rays Vet's Avatar
Rays Vet
Thanks fellows !!!! I know headers would only enhance the cam but dollar for dollar the cam still wins.And it's a given that eventually I would install headers and do cam first but either way you look at it they would enhance each other :crazy: :crazy: :crazy: Btw the tr220 would that be too much with the 2.73 gears and 3200(2.5) stall?? I'm still on the fence hoping for a deciding factor from you guys.
Old Feb 18, 2004 | 07:37 AM
Mitch C's Avatar
Mitch C
I think your car will perform alright with the TR220 with a 3200 stall and 2.73s. But you will get better performance and driveability if you had at least 3.42 gears. If I were you I would start with a good foundation, T/C, at least 3.42s and headers before I installed a cam.
Old Feb 18, 2004 | 07:42 AM
C5 CU's Avatar
C5 CU
dang...2:73 gears!, 3200TC and then a cam or headers...spend some time thinking about what you want to end up with (goal) you want to make sure mods match up and compliment one-another...other wise you will find yourself replacing existing mods with "upgrades".... consider 3:42 or at least 3:15 gears, not sure cam and 3200 TC will match to good with 2:73s????
Old Feb 18, 2004 | 08:42 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
One other thing to consider is your warranty. If your car is still under warranty the headers will not void your engine. But, as soon as you add the cam your engine warranty is gone.
To Cam vs Headers
Old Feb 18, 2004 | 08:53 PM
bk's Avatar
bk
Default Re: Cam vs Headers (Z06ufgrad2002)
Really depends on what you want to do. Gears (not the subject of your post) will make a real SOTP difference. Bang for buck, I think the cam is the way to go. Headers can certainly accent most engine mods, but I am pretty happy with the H/C system I selected through stock exhaust manifolds.
Good luck with whatever you choose. :cheers:
Old Feb 18, 2004 | 09:16 PM
Bob Chapman's Avatar
Bob Chapman
Z06ufgrad2002 is right about the warranty. Headers [good for 20-30 rwhp] will not void the warranty - a cam might. I'd do headers first as a good base for other mods.
Old Feb 18, 2004 | 09:37 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
:iagree: If you want bang for the buck put 3.42's or 3.90s. You'll feel it in the seat :D
