Recommended Programmer for LS1 Edit
Old Feb 18, 2004 | 01:19 PM
Arpad's Avatar
Arpad
8th Gear
Default Recommended Programmer for LS1 Edit
I am located in the Danbury, CT area and I am looking for a recommended programmer who can reset the electric fan on-off settings. I am of the belief that the dealer will not make these mods. I am switching to a 180 degree thermostat from 195 degree, and I want the fans to kick-on at 200 degrees, off at 185 degrees vs the 225 setting. I could just provide the PCM or is it recommended to program the PCM installed in the car? It was recommended that I avoid using the fan controller switch package that is available as aftermarket. Also, I do not feel like spending $350 for the Hypertech programmer. I welcome your thoughts.
