What does the X pipe do?
Old Feb 19, 2004 | 06:55 AM
93aqua's Avatar
93aqua
Default What does the X pipe do?
Im palnning on a new exhaust and was wondering what the x pipe does, does it effect, sound,performance or both? Thanks!
Old Feb 19, 2004 | 07:23 AM
Mr. C's 5's Avatar
Mr. C's 5
Default Re: What does the X pipe do? (93aqua)
93aqua,
The flow of the duel exhaust on your car has to be balanced. It already has a connection or H pipe to do this. An X pipe smooths out the flow somewhat better than the 90 degree angle of the H. Slight HP gains can be expected and the exhaust note pitch will be a little higher with less popping.
Old Feb 19, 2004 | 08:06 AM
mdhmi's Avatar
mdhmi
For me, the addition of a Magnaflow X-Pipe substantially diminished the sputtering / popping noise on deceleration. This improvement, while likely more pronounced on a M6, makes driving my car much more enjoyable. The X-Pipe is also a power-adder, good for one to two hp.
Cheers,
Mark
Old Feb 19, 2004 | 08:54 AM
2kbluestreak's Avatar
2kbluestreak
Default Re: What does the X pipe do? (mdhmi)
The firing sequence of most (if not all) American V8's has two cyinders in each bank firing next to each other. This puts a slightly higher pressure pulse in the dual exhaust pipes in an alternating manner. The H Pipe was designed to balance out the pressure in the two pipes; however, with its 90 degree angles, it doesn't do this well on high output engines. The X-Pipe does a better job of allowing excess pressure and exhaust gas to flow to go from right to left and left to right side exhaust pipes, :cheers:
Old Feb 19, 2004 | 11:47 AM
BlackMagicC5's Avatar
BlackMagicC5
Default Re: What does the X pipe do? (2kbluestreak)
Anyone here have the slp loudmouth setup, drove it, then added an x pipe?
Old Feb 19, 2004 | 01:40 PM
The X-pipe smooths out the exhaust flow and will help reduce resonance and backpopping. There may be some performance gain, but very minimal.
Old Feb 19, 2004 | 04:49 PM
CR555's Avatar
CR555
The reason an X-Pipe crossover works better than an H-pipe crossover isn't more flow because of volume, but more effective use of exhaust gas velocity. Exhaust gas (or air) has surface tension, and flows much like liquid would through the same pipe system. As the cylinders of each bank on a "V" style motor fire, they create a pulse in the system. The pulses will alternate back and forth from bank to bank as the motor runs. With multiple cylinders, such as a V-8, the eight cylinders alternately fire creates lots of pulses in the system.
If you put your hand behind the tailpipe, it would feel like a constant flow of air, but what it really is a lot of singular pulses giving the impression of constant flow. The idea behind the H and X style crossover is to unite the two banks of cylinders for better exhaust gas scavenging. Instead of two separate banks of four cylinders doing their own work, the crossover uses the pulse created by a firing cylinder of one bank to create a vacuum in the other bank because of surface tension. When a cylinder of the other bank is ready to fire, instead of the piston having to force the exhaust gas out of the cylinder, the vacuum that was created by the other cylinder bank helps suck the exhaust gas out of the cylinder, hence the term "scavenging."
Whenever you can reduce the load on an internal combustion engine, you are likely going to see performance and efficiency benefits. The difference between an H and X crossover is a smoother path for the exhaust gas to follow. Exhaust gas, like a liquid, will follow a path with the least amount of resistance. An H crossover has a path with two sharp 90-degree angles that are close together. An X crossover has a path with a much more gradual bend to allow the exhaust gases to continue their path back out to the ends of the tailpipes, rather then turning sideways for a short distance, then turn again to head out the tailpipes. Smooth flow with high velocity means more power by use of scavenging. Using an exhaust system with too large of piping diameter work against scavenging in the same way that running an exhaust with too small of tubing chokes the motor and forces it to work harder to expel the exhaust gases.
Old Feb 19, 2004 | 08:18 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: What does the X pipe do? (CR555)
Very nice explanation CR555
Old Feb 19, 2004 | 08:20 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: What does the X pipe do? (JDs00PewterCoupe)
:withstupid:
Old Feb 19, 2004 | 10:50 PM
morespeed's Avatar
morespeed
wow! that explanation was so good I am going to go buy one for my car just because it sounds efficient :)
To What does the X pipe do?
