DRM IS NOW A SUPPORTING VENDOR!!!!!!
Old Feb 21, 2004 | 02:27 PM
  #41
vettethret's Avatar
vettethret
Default Re: DRM IS NOW A SUPPORTING VENDOR!!!!!! (Randy@DRM)
No problem. I thought it is better to be lower i.e lower center of gravity. I look at the c5r and that thing is on the ground. I do notice my car has a lot of over streer but still corners unbelieveably.. Just for my own education, If we've had a shorter suspension set up made for increased travel, what is detremental about being slammed on ther ground? What beneifts come from a taller ride height than I'm at..
Thanks Randy :cheers:
Old Feb 21, 2004 | 04:58 PM
  #42
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: DRM IS NOW A SUPPORTING VENDOR!!!!!! (vettethret)
I've heard of you guys but never saw you around on the Forum. Good to have you aboard. :yesnod:
Old Feb 21, 2004 | 08:27 PM
  #43
RyanC7's Avatar
RyanC7
Here we go again another header choice......
Old Feb 22, 2004 | 04:53 PM
  #44
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I think it would best if we talked more about your suspension over the phone. I was left out of the loop with the shorting of the shocks. I heard aboout it and that was about it. I would like more imput from you the owner. There is nothing the same between your car and the C5R, when building a racecar you finish the chassis and then build boday work around it. They have a way different suspension setup then a average C5. Please give me a call sometime this week. (763)477-9272
Randy
Old Feb 22, 2004 | 05:10 PM
  #45
vettethret's Avatar
vettethret
Thanks Randy. I'll give you a call tomorrow and go over where I'm at now and take your advice. Once again welcome to the board. :cheers: :flag
