Does the check engine light pull timing
Old Feb 19, 2004 | 10:51 PM
402Sam's Avatar
402Sam
Default Does the check engine light pull timing
I removed my cats and I installed the o2 sims awhile back. Every now and then I get the check engine light. But I usually just reset it while driving and it doesnt come back on. But when it is on is the ecu pulling timing out. I know on my buddies mustang he did the same and he has the check engine light on and he said it is pulling 5 degrees out on his car.
Old Feb 20, 2004 | 01:11 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Does the check engine light pull timing (sprayedc5)
As far as I know the Check engine is strictly emissions reporting and does not interact with engine controls but I could be wrong. Have you looked at the codes to see what is being reported?
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Feb 20, 2004 | 04:13 AM
rwj383's Avatar
rwj383
Default Re: Does the check engine light pull timing (Richin Chicago)
If you're just getting HO2B1S2 and B2S2 low voltage codes, timing is not being affected.
Old Feb 20, 2004 | 06:08 AM
kumar75150's Avatar
kumar75150
Default Re: Does the check engine light pull timing (rwj383)
I think it depends on the codes.
I remember that clearing the codes at the track one time netted me 3mph. Might just have been dumb luck.
To Does the check engine light pull timing
