PART IDLER PULLY MOUNTS TO BROKE OFF
need help, the part the idler pully mounts to broke off. its the piece the bolt goes through to secure the idler pully, is that part of the water pump, or is it the bracket that holds the alt and p/s pump? 2000 coupe
Re: PART IDLER PULLY MOUNTS TO BROKE OFF (birch64)
If you are talking about the tensioner pulley up top on the passenger side of motor, it bolts to the water pump. If the mounts broke on that you would need a new waterpump.
its the pulley on driverside between the hermonic balancer power steering pump and water pump, under the power steering fluid resurve.........
