Idle problem-help
Old Feb 22, 2004 | 09:08 PM
bob98's Avatar
bob98
Default Idle problem-help
On my 98 6spd with 70K, when coming to a stop with the clutch in, the idle will drop to around 400, then the times it doesn't stall, it will go back to 750 or so. The dealer could not find a problem, said all checks are normal. It is worse with the air on. I hate to go to the dealer anyway so if anyone has an idea, I would apreciate it.
Old Feb 22, 2004 | 09:20 PM
jojog's Avatar
jojog
Default Re: Idle problem-help (bob98)
Ever change your fuel filter - just a thought. :thumbs:
Old Feb 22, 2004 | 10:29 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Idle problem-help (jojog)
look at the fuel filter.... next look at your air bridge??? Do you have an alum flywheel??? This is a common occurance with alum flywheels
[Modified by ICULUKN-C5, 8:30 PM 2/22/2004]
Old Feb 23, 2004 | 10:45 PM
bob98's Avatar
bob98
Default Re: Idle problem-help (ICULUKN-C5)
car is bone stock except for K&N filter, will check fuel filter--thanks!
Old Feb 24, 2004 | 03:01 PM
BlackBlur's Avatar
BlackBlur
I have a 98 6sp with about 65k and I am having the same problem. I have taken it to two different shops and they cannot find anything. Please let me know if the fuel filter is the cause of your problem. Also regarding the aluminum fly wheel, is the stock fly wheel on a 98 C5 aluminum? Thanks.
Old Feb 24, 2004 | 07:22 PM
dpd's Avatar
dpd
you probably have a dirty throttle housing.get some throttle housing cleaner,take the duct off and clean out the throttle.
Old Feb 24, 2004 | 09:11 PM
bob98's Avatar
bob98
Default Re: Idle problem-help (dpd)
Does not seem to be fuel filter. dpd---I am not familiar with throttle body cleaner, is it similiar to carb cleaner and do you use it the same way? Can you purchase at auto supply stores?
Old Feb 25, 2004 | 03:23 PM
bob98's Avatar
bob98
Default Re: Idle problem-help(it did) (bob98)
Got the throttle body cleaner, used it and it seems to have helped the problem--will only know for sure after it gets really hot, but no doubt it is better
Old Mar 2, 2004 | 10:23 AM
BlackBlur's Avatar
BlackBlur
dpd, BIG thanks for the information. That has seemed to fix the problem with my car. It is running better that it has since I have owned it. Idle has not once dropped below 700rpm even after extended driving.
:hurray:
To Idle problem-help
