The GM manual states that during the first 500 miles you can't go over 55MPH and no sustained engine speeds (high or low).
Here in Arizona the speed limit is 70-75 MPH. If you are doing 55 MPH then you will cause a traffic jam or an accident.
Is it better to keep the RPMs low than the actual MPH. I keep the RPMs BELOW 3500RPM and no hard starts. I kept fluctuating the speeds between 65-80MPH and the RPMS never went above 2400RPM.
Any input?
I have nothing to base this on but my own experience but I feel it is important to vary your engine speed more than just hold to some low limit. I would be all over the place with an occasional redline. Moderate, variable, with a few bursts.
They just don't want you to take it off the show room floor and run the crap out of it. Use good judgement and once you hit the 500 miles, then run the crap out of it. :D :thumbs:
:iagree: Just be nice to it for the first 500hundred. Vary the engine speed, and enjoy the ride.
I just got to 450 miles and heck I tried like everything, but I had to get on it a little. I did some highway, some traffic, and let it idle on couple really ugly days when it had not been started for a week.
Nothing out ragious but what I would call normal driving for a car, 50 more miles and then I can drive it like a Vette :yesnod: :yesnod:
The reason for not keeping the Engine at the same RPM is for seating the piston rings properly. The reason for not going over 55 MPH for 500 miles is for getting a good wear pattern on the Ring and Pinion gears.
I would try to adhere to this the best you can.
I had a similar problem since I picked my car up 350 miles from home. I ran it on back roads for the first couple of hundred miles and then took it easy on the highway. It was scary, but careful to adhere to the owner's manual.
