Header Bolts - what is everone using?
Old Feb 26, 2004 | 07:14 AM
Coolvet's Avatar
Coolvet
Default Header Bolts - what is everone using?
Is there one header bolt design that is better than the others?
Old Feb 26, 2004 | 01:17 PM
Smokin Joe's Avatar
Smokin Joe
Default Re: Header Bolts - what is everone using? (Coolvet)
I would like to know the answer to this as well.
Old Feb 26, 2004 | 01:28 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I used the stock bolts and 4 of the stock exhaust header down pipe stud nuts.
Worked fine - In fact I re used my factory gaskets too
Old Feb 26, 2004 | 02:01 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Stock bolts and gaskets here also :thumbs:
Old Feb 26, 2004 | 02:19 PM
wrustywrench's Avatar
wrustywrench
Default Re: Header Bolts - what is everone using? (Flyin'Brian)
stock,,, would have prefered stage 8 ,, but it would be a real pain to install the clips....just check after a few heat cycles, re-torque
Old Feb 26, 2004 | 03:49 PM
Blow Torch's Avatar
Blow Torch
Default Re: Header Bolts - what is everone using? (Ragtop_Rob)
I used the stock bolts and gaskets as well - No issues at all.
Old Feb 26, 2004 | 04:48 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: Header Bolts - what is everone using? (BOTTLE FED)
A recent Hot Rod Magazine showed in their new product review section a header bolt that has the lower threads split axially in four places. The outer part of the bolt is hollow and threaded for a set screw that is supplied. It is supposed to work by tightening the set screw, which forces the lower part of the bolt outward to lock it tighter into the tapped hole in the head. Cost was $100 for an engine set: pretty high. The reviewer remarked that loosening the set screws in a couple years might be a problem. Personally, I've often wondered if headers leak and header bolts become loose due to the exhaust gasket collapsing a little. If this were the case, having a locking header bolt is no solution. :cheers:
Old Feb 26, 2004 | 05:34 PM
RONS97C5's Avatar
RONS97C5
stock bolts and gaskets here
Old Feb 26, 2004 | 05:52 PM
jmX's Avatar
jmX
Default Re: Header Bolts - what is everone using? (RONS97C5)
Me 7....stock bolts and gaskets.
Old Feb 26, 2004 | 05:54 PM
bruce1's Avatar
bruce1
I went with ARP studs....
Old Mar 1, 2004 | 04:45 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Header Bolts - what is everone using? (2kbluestreak)
The cost for the header bolts was $53.85 for a black oxide finish or $64.00 for the polished finish, and you can also buy intake bolts for the same price but who really has a problem with intake bolts :rolleyes:
and their website is www.go-breslin.com
Old Mar 1, 2004 | 07:22 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I spoke with LGM about this issue. Their recc. was use the stock bolts and gaskets.
Old Mar 1, 2004 | 07:54 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Stock bolts and gaskets shoould be all you need for this operation, jsut remember to go back over them after you first dirve the car and retoruqe them.
Old Mar 1, 2004 | 08:05 PM
msuc5vette's Avatar
msuc5vette
:yesnod:
Old Mar 1, 2004 | 08:08 PM
Wt99C5's Avatar
Wt99C5
If you think you'll be removing the headers from time to time, get the studs.
If they're going on and staying on, use the stock bolts.
Old Mar 1, 2004 | 08:10 PM
corvettebob1's Avatar
corvettebob1
Default Re: Header Bolts - what is everone using? (msuc5vette)
Stock bolts and re-torque them after a few heat cycles. :cool:
Old Mar 1, 2004 | 11:05 PM
blackjack's Avatar
blackjack
Default Re: Header Bolts - what is everone using? (corvettebob1)
Stock bolts. New gaskets and lots of anti-sieze...
To Header Bolts - what is everone using?
