On C5's are all the tire sensors the same?
I just got a set of rims with sensors in them, and tried to train... not one honk... So... ALL are dead.... or they are a different sensor. I have a 98 and the rims were from a 2003.... Let me know :smash: :crazy: :seeya :auto: :steering: :leaving:
Re: On C5's are all the tire sensors the same? (AtHomeSoda)
Here are the part numbers:
1997 - 2000 10438853 sensor 10268438 seal 10268439 nut
2001 - 2004 25648293
Re: On C5's are all the tire sensors the same? (Richin Chicago)
The label on mine (98) has a Bar Code... Says SBI Inc. 1181261 Ad it has a # GM10402716 Is that the part....? Help.... are the other sensor a fifferent shape..smaller? :smash: :banghead: :chevy :seeya :auto: :hurray: :leaving:
Go to this website: http://www.schraderelectronics.com
They make the 2000 and up sensors. Check the photos and see what your sensors look like.
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Re: On C5's are all the tire sensors the same? (EHS)
'97-'00 big.....'01-'04 small
ummmm, :nono: that would be 2001 and up. not 2000 and up.
'97-2000 sensors are the same
edit>>> I guess I read that too fast. I see what you're saying now :banghead:
[Modified by Flyin'Brian, 6:53 AM 2/27/2004]
Re: On C5's are all the tire sensors the same? (Flyin'Brian)
Oh, :nono: :nono: :nono:
I wasn't talking about sizes, model year differences, or "sameness." I was speaking to the manufacturer of the sensors. That's who the link I referenced is for:
As I stated, Schrader Electronics makes the 2000 and up sensors. Here's a picture for you:
2000 sensor (the "old large" one)
2001 and up (the "new small" one)
GM part numbers and list prices are as follows:
'97-00: Sensor PN 10438853 $126.25; Retaining Nut PN 10268439 $1.88; and O-ring Washer PN 10268438 $1.88.
'01-current: Sensor with O-ring PN 2571358 $80; Retaining nut PN 25708165 $3.68.
Hope this helps. :smash:
[Modified by EHS, 9:11 PM 2/26/2004]
Location: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Actually both generations of sensors are made by Schrader-Bridgeport Inc.
hence the SBI on the mfg label.
The advice given above is correct you have the smaller sensors 01-04 and need to swap out to the earlier version for your BCM/TPM/RFA to hear them when you are training them up.
[Modified by XmentalPilot, 8:27 PM 2/26/2004]
Re: On C5's are all the tire sensors the same? (XmentalPilot)
Nice RV-4, BTW; glad to see some still fly conventional(ly). Since you're in Washington, have you been to the factory?
I may be splitting hairs, but I only commented on the 2000 and up sensors. I don't have any experience with the earlier sensors, so did not want to speculate on who made them. The part numbers are the same, so I should have assumed they were made by the same manufacturer.
Just so we are all on the same page the part numbers don't change until 2001?
2001 - 2002 25648293
"It's 2001 and up."
"It's 2001 and up."
"It's 2001 and up."
For example, 2002 Z06 wheels are made by both Alcoa and Speedline; the part numbers are the same, nevertheless the wheels are different in both manufacture and appearance (forged vs. spun, angular vs. more rounded spokes, darker color vs. lighter color). And the Speedlines even weigh less, all with the same part number. I went through this issue when I bought my OEM wheels from Fichtner.
I only know that Schrader made the 2000 sensors, and made the 2001 through 2004 sensors. I don't know if the earlier one's were made by someone else (like, say Beru); hence, I originally posted that Schrader Electronics made the "2000 and up sensors," because I didn't know that the "1999 and down" sensors were made by them, even if the part numbers are the same.
Just like I wouldn't post that all Z06 wheels are made by Speedline, only that some of the "2002 and up" wheels are made by Speedline. :banghead: :banghead:
Received 19,875 Likes
'20-'21-'22-'23-'24
'97 to '00 were the same, then '01 - '04 are the same. Your system will not recognize the '03 sensors.
