HESITATION???????????????
Old Feb 28, 2004 | 02:19 PM
JSMITH1615's Avatar
JSMITH1615
Default HESITATION???????????????
MY 2004 C5 SEEMS TO HESITATE WHEN I PUNCH IT OR ENTER THE HWY. ITS LIKE IT BOGS DOWN. I DID ADD CORSE EXHUAST AND X PIPE BUT IT SEEMS LIKE IT JUST STARTED. ANY IDEAS???
Old Feb 28, 2004 | 04:20 PM
dpd's Avatar
dpd
Default Re: HESITATION??????????????? (JSMITH1615)
could be a lot of different things.first did you check for faults?do you have any air leaks?did it start after getting fuel?
Old Feb 28, 2004 | 10:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: HESITATION??????????????? (dpd)
This may seem like an IDIOT check but,,,, when it does the HESITATION thing take a quick look at the DIC and see if it says "traction control active" or something like that!!!
If it is, your Body Control Module is applying the brakes!! I let a friend of mine drive my 98 a little crazy once and he thought that the car was a dog and I thought he was driving like a sissy! It took us a while to realize that the Traction Control was in normal and the traction control was kicking in! :crazy:
My 02 ZO6 has "COMPENTITION MODE" which allows me to blaze the rear tires but keep the stability by using the "Active Handling" mode
If you want to get real crazy, just turn both to off!!! :crazy: :crazy: :thumbs: :thumbs: :D I love to draw pretzles in the parking lot!!!!!!!!!!!!!!!!!!! :D
BC
Old Feb 28, 2004 | 11:13 PM
dogdoc97's Avatar
dogdoc97
HI, you do not say if the car is auto or 6 speed; auot's will hesitate, as they kick down as well as what is called "fly by wire" as some techs call itl my A4 woudl feel like the rear end "grabbed"the road in the rear, then shot off....all normal......dogdoc :cool:
Old Feb 29, 2004 | 11:21 AM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Default Re: HESITATION??????????????? (dogdoc97)
Hi . Did you do any mods to the intake system?
If its an auto trans- try driving in D3 while under 50mph. That may help.
at slow speed autos tend to shop around for the right gear for your speed.
good luck :seeya
:flag
To HESITATION???????????????
