Safe to plug a run flat??
Old Feb 28, 2004 | 08:31 PM
Calvet01's Avatar
Calvet01
Default Safe to plug a run flat??
Got a screw in the middle tread area. (rear tire) Is it safe to remove and plug........Thanks in advance for replys :confused:
Old Feb 28, 2004 | 08:54 PM
Fast98's Avatar
Fast98
Default Re: Safe to plug a run flat?? (Calvet01)
I would get a patch from the inside
Old Feb 28, 2004 | 09:03 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: Safe to plug a run flat?? (Fast98)
:iagree: Same thing happened with me. Had it patched worked fine.
Bob
Old Feb 28, 2004 | 09:15 PM
Billf6531's Avatar
Billf6531
What you want is a 'mushroom' repair. Both a plug and a patch. Mentally picture a mushroom. The plug ensures that no moisture will enter the tread to rust any of the wire structure in the belt, and the patch prevents air loss.
:cheers:
Old Feb 28, 2004 | 09:25 PM
JeremyMSG's Avatar
JeremyMSG
Default Re: Safe to plug a run flat?? (Billf6531)
:cheers:
:iagree: Used to work at a tire shop. This is the best method.
Old Feb 28, 2004 | 10:25 PM
88sk's Avatar
88sk
Default Re: Safe to plug a run flat?? (jeremytsi)
got a screw in the rear (no jokes),I plugged it & works fine.
Old Feb 28, 2004 | 11:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree about the mushroom patch.
Bill / jeremytsi
Where can you find that kind of patch?? I have a new motor cycle tire that needs a patch and I am looking for that kind of patch!!!
Please let me know.
BC
[Modified by Bill Curlee, 10:08 PM 2/28/2004]
Old Feb 29, 2004 | 12:04 AM
Billf6531's Avatar
Billf6531
Default Re: Safe to plug a run flat?? (Bill Curlee)
Sorry, I probably didn't explain it well. It's actually two steps. First plug the tire, and trim the plug flush on the inside. Then put a patch on the inside, over the plug area.
Bill / jeremytsi Where can you find that kind of patch?? I have a new motor cycle tire that needs a patch and I am looking for that kind of patch!!
Old Feb 29, 2004 | 12:30 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:iagree: :thumbs:
Old Feb 29, 2004 | 12:32 AM
LittleBoyBlu99
Welcome to the forum (Calvet01) :seeya Drive safely :thumbs: :cheers:
Old Feb 29, 2004 | 08:11 AM
coolcat's Avatar
coolcat
Default Re: Safe to plug a run flat?? (88sk)
Did you light up a cigarette after you finished the plug? :jester :lolg: :lol:
Old Feb 29, 2004 | 08:43 AM
AFVETTE's Avatar
AFVETTE
Yes but I told you lose the speed rating. The non run flat crowd faces that delima everyday, plug or walk.
Tom
Old Feb 29, 2004 | 09:41 AM
ndirishr1's Avatar
ndirishr1
I had mine fixed with the plug and the patch method and it has held up well. Plug alone will not hold.
Old Feb 29, 2004 | 02:35 PM
SpinMonster's Avatar
SpinMonster
Default Re: Safe to plug a run flat?? (ndirishr1)
EMT repair kit from STS. It is both a plug and patch. There is no loss of speed rating as per goodyear. I got the flat when the tires had 3k on them. I had gone 177 and numerous runs over 150mph after the repair. I sold the tires after 12k and never had any problems with the repair.
Old Feb 29, 2004 | 02:57 PM
allanlaw's Avatar
allanlaw
Default Re: Safe to plug a run flat?? (SpinMonster)
Asw long as the hole isn't too close to the edge of the tire, it will work fine after repair on the inside.
Old Feb 29, 2004 | 03:18 PM
billiam01's Avatar
billiam01
No problem; my Chevy dealer has patched one in the front and one in the back. I wouldn't push the speed rating though. If it wasn't done well you would have a slow leak. As for the motorcycle, I have two, I wouldn't do it. I haven't found any motorcycle shops willing to do it. Just get a takeoff or buy brand new.
Old Feb 29, 2004 | 08:11 PM
DIAMOND DAVE's Avatar
DIAMOND DAVE
I can tell you that I have had a plug in mine the first week I bought the car and have had them plugged probably five times and not a problem .
Good luck as it sure is a bummer to have to plug a tire the first week. :mad
To Safe to plug a run flat??
