MAF & IAT issues & question..
Old Feb 29, 2004 | 09:16 AM
YO-EL's Avatar
YO-EL
Default MAF & IAT issues & question..
Should I convert my 2000 MAF & air duct located IAT sensor to the 2001+ Pace or (01 stock) MAF with all in 1 harness, OR get NEW wiring harness for the MAF & IAT sensors, as I think they may be bad..
Thoughts or experiences are appreciated.
Ellis
Old Feb 29, 2004 | 01:53 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Re: MAF & IAT issues & question.. (YO-EL)
I'll say that when my '99 started throwing IAT codes I assumed that the sensor was bad. Replacing it did no good and I found out soon after that it is common for the IAT harness to go bad on the pre '01 cars with seperate IAT sensors. The part # for the harness was 12102620. and it was like $25.
If you got the pace MAF the IAT harness woud plug into it and you would still have the problem if the harness is indeed bad. I would replace the harness and see if your problems go away.
HTH :cheers:
Old Feb 29, 2004 | 04:28 PM
YO-EL's Avatar
YO-EL
Default Re: MAF & IAT issues & question.. (5 Liter Eater)
Yes, I am thinking about getting the IAT & the MAF harness anyway.
To MAF & IAT issues & question..
