90mm Fast install
Old Feb 29, 2004 | 07:04 PM
gojo's Avatar
gojo
Default 90mm Fast install
Nick and I installed the Fast 90mm and one of his TB's this weekend. It's not like swapping stock intakes. There are some small issues to deal with, that once you've done it the next is easy. The manifold fits, but there are tubes and wires by the fire wall that need to be moved and a couple of extensions
are needed. Once it's torqued down everthing clears. It is tight, though. Tuning the throttle body was tough at first. I had installed a bigger cam last week and the IAC and RAF values had to go way up to give the cam more air.
The throttle body, on the other hand pushes so much air that my tables are now lower than stock. It picked up 3 Maf ft lbs. From 42 to 45. That's a lot of air. This setup should be really good on big cube engines.
I picked up 15 hp and 35 tq with cam and 8hp and 10tq, more, with the intake. I'm at 382 hp and 429tq. All runs unlocked. The HP is what I expected, but the torque is a pleasant surprise and I can feel it big time. There was no tuning done for the dyno, either time.
Better photos http://www.shutterfly.com/osi.jsp?i=...21b349ee3f05f4
[Modified by gojo, 11:52 PM 3/1/2004]
Old Feb 29, 2004 | 10:11 PM
RWhite's Avatar
RWhite
Default Re: 90mm Fast install (gojo)
Nice numbers. Thats about the power I was making with my set-up when I went high 10's. So get to the track !
It seems like our cars will almost be clones, btw I just put on a FAST intake and 90mm TB today. :cheers:
I really wanted to get some same day dyno numbers to compare intakes, but like you I heard that you need to do some tuning to get the IAC's and other points dialed in. I will dyno next week sometime. :seeya
[Modified by RWhite, 9:12 PM 2/29/2004]
Old Feb 29, 2004 | 10:32 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Congrats Joe!!
Incredible increase in Torque. :thumbs: :D I think the FAST looks alot better than the stock manifold...I hadn't seen a decent pic on a motor. Are the 90 mm TBs now available?? Thanks!
gojo's Avatar
gojo
Default Re: 90mm Fast install (RWhite)
Thanks Roger, I wish mine was a clone of yours. I got it running pretty well today. The cam is not too big and was designed to be streetable, so I gave up some power. My plan was to run low 11's. But, I secretly, would really like to break into the 10's. We'll see.
Old Feb 29, 2004 | 10:35 PM
C5 YA's Avatar
C5 YA
The pic shows the FAST Intake manifold in black. This is the first manifold that I have seen from FAST that is black. Is this how they are selling their manifolds now? It looks allot better than the white nylon material that they were previously using.
Old Feb 29, 2004 | 10:47 PM
gojo's Avatar
gojo
Default Re: 90mm Fast install (binksZ06)
Thanks Joel, a nice feature is how well it runs on the street. I'll see if I can get better pictures during the day. The TB is really pretty.
LG sells the TB's.
Old Feb 29, 2004 | 10:50 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
LG sells the TB's.
I'm sold. :D I'll call LGM tomorrow.
gojo's Avatar
gojo
Default Re: 90mm Fast install (C5 YA)
Sorry, it's light gray. My viewer shows the right color. It looks really good with LG's TB.
Old Feb 29, 2004 | 11:04 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Jeez you picked up 45 lbft of Torque! I'll bet it's a FUN Feature! :D
I was hit by the MyDoom virus last week...long story....fixed now. I'll email you tomorrow.
[Modified by binksZ06, 11:12 PM 2/29/2004]
Old Feb 29, 2004 | 11:17 PM
gojo's Avatar
gojo
Yes it's fun and it's scary as sh_t when you kick it at 60mph and it goes sideways. Racing is for the track only now. :crazy:
Old Feb 29, 2004 | 11:22 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Adrenalin (epinephrine) is a good thing........and your reflexes caught it (i.e. it didn't swap ends). :yesnod: :thumbs:
Old Mar 1, 2004 | 03:03 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Wow :eek: Are all the tq's coming from your LS6 TEA heads?
I haven't seen that much tq's!
[Modified by mike76002, 2:03 AM 3/1/2004]
Old Mar 1, 2004 | 09:03 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
You kept the stock MAF?
Old Mar 1, 2004 | 09:19 AM
RWhite's Avatar
RWhite
I e-mailed you a few minutes ago about our install. Jeff may follow up later today with his comments. He has some more tuning to do, but it is up and running. We are going to strap on the Mickeys to see if we can feel any SOP increases. :D :D :cheers:
Old Mar 1, 2004 | 12:11 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Keep us posted Roger". :cheers: :hurray: :hurray:
Old Mar 1, 2004 | 12:22 PM
2KREDVert's Avatar
2KREDVert
Default Re: 90mm Fast install (LittleBoyBlu99)
What did you install for a cam last week?
Old Mar 1, 2004 | 01:51 PM
gojo's Avatar
gojo
Default Re: 90mm Fast install (philipswanson)
I went from a 222/568 to a 228/588. Still ababy by todays standards. It is very streetable for me. I would not want bigger.
To 90mm Fast install
Old Mar 1, 2004 | 01:52 PM
gojo's Avatar
gojo
Default Re: 90mm Fast install (mike76002)
Probably am getting a big boost from the converter.
Old Mar 1, 2004 | 02:05 PM
gojo's Avatar
gojo
Default Re: 90mm Fast install (Buckmaster)
I did. It's an 85mm and should handle it. I'll wait until someone shows a bigger one is better.
Old Mar 1, 2004 | 02:23 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
I was wondering the same thing and thinking of doing the same thing--I still have a modded stocker from the 2000---
