From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Radiator hoses collapsed when engine is cold....?
I am not too familiar with the closed system used in the LS1 but is it normal for the hoses to be collapsed flat when the motor is off and cold? When I open the cap on the fender the vacuum is released and they pop right out.... Normal or a problem here? :cheers:
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Re: Radiator hoses collapsed when engine is cold....? (Crazy C5 Cowboy)
________________________________________ ________________________
I have a 98 coupe that had the same problem. I replaced the radiator cap and all is well. :)
Dude, it's very normal but you have to stop opening the radiator cap.
I have been told (and read it somewhere here) that exposimg Dexcool to oxygen is what makes it gel up. I've also read, and abided by, the advice to change the Dexcool every year. Some folks swap out the Dexcool for plain old glycol anitfreeze. I dont know enough about a swap to advise.
:thumbs:
Cruise-In V Veteran
Re: Radiator hoses collapsed when engine is cold....? (keith5)
Thanks, I just changed it when I built the motor a couple months ago. I'll do the radiator cap tomorrow and see what results happen! Appreciate the info guys :cheers:
I dont know what everyone else said in this thread, but far from the popular belief... I think you need a new radiator cap.. But then what do we know...
Re: Radiator hoses collapsed when engine is cold....? (Evil-Twin)
Jesus Christ!!! cant you read the 6 or 7 replies?? :skep: :jester
Re: Radiator hoses collapsed when engine is cold....? (vetterdstr)
VR :cheers:
Too many Playboy magazines as a youngster vetterdstr.. I should have listend to my Mom... I am blind because of it :cool:
