STOP FORCE Rotors
Old Mar 4, 2004 | 02:20 PM
00TORCHCOUPE's Avatar
00TORCHCOUPE
Default STOP FORCE Rotors
I have done search and see that some are using them. Please chime in and say how happy you are right now, what you are using in the rear, and what application conditions you are putting them under. I am thinking about replacing my rotors with them.
Old Mar 5, 2004 | 06:52 AM
00TORCHCOUPE
Default Re: STOP FORCE Rotors (00TORCHCOUPE)
TTT
Old Mar 6, 2004 | 08:19 AM
00TORCHCOUPE
:lurk:
Old Mar 6, 2004 | 09:13 AM
Hirohawa's Avatar
Hirohawa
ttt. Curious about these as well. I need new rotors and these are on the list of potentials.
I have read that peopla are using teh KVR performance rear rotors that match the hole pattern of the Stopforce.
Old Mar 6, 2004 | 01:22 PM
glp13760's Avatar
glp13760
I have a pair of StopForce fronts and KVR rear rotors in my garage, awaiting installation on my brother's 03 Anniv Edition. I won't be installing them for another month or so, so I can not tell you how well they perform, but I can tell you that they LOOK GREAT.
The StopForce rotors, http://www.stopforce.com , came direct very quickly from California, and I ordered the KVR rear rotors from Strano Auto Parts http://www.stranoparts.com , in Penn, and they were dropshipped form KVR. Both suppliers had them on my doorstep in a week. Pretty good service in my book! :thumbs:
Regards, Gary.
Old Mar 7, 2004 | 07:05 AM
00TORCHCOUPE
Default Re: STOP FORCE Rotors (glp13760)
Thanks, that is a start. I know I read some people that had them installed. I just want a status report.
Old Mar 7, 2004 | 09:37 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
I have the Stop Force too, (sorry not on yet) can you give me the part # on the rears? I have been looking for a close match that why I have not put them on yet. Thanks :cheers:
Old Mar 7, 2004 | 05:47 PM
glp13760's Avatar
glp13760
Default Re: STOP FORCE Rotors (Z06GMAN)
The KVR rotors I got were ordered from Strano Auto, The rear p/n's are 55211RCD-3 (Right-rear) and 55211LCD-3 (Left-rear). I got them from Strano, but they were not in the catalog. I emailed them, and they emailed me back with the price. They were $232 for the pair, plated. I was very happy dealing with them. They had the KVR rotors dropped shipped direct to me.
Regards, Gary. :seeya
Old Mar 7, 2004 | 06:50 PM
kumar75150's Avatar
kumar75150
Stranoparts.com has them for 97.50 each.
When you talked to them, did you specify that you wanted drilled only to match the Stopforce fronts?
Old Mar 7, 2004 | 07:51 PM
glp13760's Avatar
glp13760
Default Re: STOP FORCE Rotors (kumar75150)
Kumar - The $232 was the "delivered to my door price" for a pair of plated (either silver, black, or gold color) rotors. The quote on the plating was $32 per pair of rotors, and the balance was shipping. To match the StopForce hat color, I had them done in black. By the way, when I contacted KVR direct in Canada, they quoted me a much higher price (in US dollars), and it did not include the shipping costs. Strano was much cheaper. :hurray:
I did not specify a special hole pattern. (Actually... I never thought of it!) The hole pattern is very similar between KVR and StopForce, but not exact. Obviously, the fronts have more surface and therefore more holes, The front StopForce rotors alternate between 4 and 5 holes in a row (in an arc pattern) and the KVR rears have 3 holes (in a similar arc). Sorry, but I don't have the ability to post pictures, or I could show you.... :rolleyes:
Here's the links...
KVR rotors, @ Strano Auto Parts http://www.stranoparts.com
Hope this helps.... Gary.
[Modified by glp13760, 7:53 PM 3/7/2004]
Old Mar 7, 2004 | 08:50 PM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
Cruise-In VII Veteran
St. Jude '03-'04-'05-'06-'07-'09
I had KVR's all-around and warped and cracked the fronts at Road America. I kept the rears, but replaced the fronts with Stop Force. Only been on the street so far, but they will get a Road America workout in April...
Old Mar 7, 2004 | 10:40 PM
kumar75150's Avatar
kumar75150
Thanks a lot Gary.
Thats probably the setup I will end up going with.
Old Mar 8, 2004 | 05:55 AM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
I have Stop Force on my car with HP+ pads... in back I put eradispeeds. I know the patterns do not match. But so far no one has noticed the difference.
With the HP+ pads the braking perfromance is dramatic compared to stock. They are very agressive when warmed up (noisy too!) but I am willing to tolerate the noise kowing that I have some pretty serious braking power available whem I need it. Love the Stop Force rotors!!
Old Mar 8, 2004 | 07:09 AM
Tom T.'s Avatar
Tom T.
Default Re: STOP FORCE Rotors (XmentalPilot)
I've had one track day so far with the Stop Force rotors, and they worked very well. Pads are KFP Magnum. Second track day is tomorrow. Left the "old" Eradispeeds on the rear for now.
TT :cheers:
To STOP FORCE Rotors
