I get the passenger side header on and the AIR hose/bracket does not even come close to the header bracket where it is supposed to attach. Like 4 inches apart. I have a 2000 cpe.
pre 01 the air tube goes to cyl #8
01's and up the air tube goes to cyl #6
I wasn't happy with the fit even with the correct air tube.
took some messing around, but here's the results.
Block off the headers and you can just leave them disconnected for now. I am, it is just a pump, which only works upon start-up for emmisions. You may need 02 simms to leave it off though. I did not throw any codes.
I have O2 sims, because I am not tuning it until later (therefore turning the sensors off. The AIR is still connected to the car, just not to the bracket.
Got the newer intake already!!!
I'm just one of those guys that likes to do it right and complete. Thanks for your help.
