Training new remote?
Old Mar 6, 2004 | 12:23 PM
Dope's Avatar
Dope
Resident moron
Default Training new remote?
Hi guys,
I followed the instructions I found on here about training a new remote. I only got one fob with my car (the #2 I think), and I bought a #1 online. It's the right part number, and the battery is good (I swapped batteries just in case).
This is what I tried: turn car to On (but not started). Hit reset to get rid of Door Ajar message. Then cycle through options till I get a blank DIC. Hold reset till I get FOB TRAINING. Then I let go of reset. I held lock/unlock on the fob for a good 45 seconds and nothing. Then I tried holding reset and lock/unlock on the fob for another 45 seconds. I tried it a good few times, got nothing. Am I doing it wrong? Or am I gonna have to go after this guy for selling me a bad fob?
Dope
Old Mar 6, 2004 | 12:33 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Training new remote? (Dope)
hmmmm..nether FOB "took"?
Old Mar 6, 2004 | 01:03 PM
Dope's Avatar
Dope
Resident moron
Well, the first fob is fine, it came with the car. We bought a 2nd one online to have as a spare, but it won't train.
Dope
Old Mar 6, 2004 | 01:33 PM
Richin Chicago's Avatar
Richin Chicago
Hi guys,
Dope
That proceedure doesn't sound quite right. It's in your owner's manual.
Old Mar 6, 2004 | 06:03 PM
Dope's Avatar
Dope
Resident moron
Default Re: Training new remote? (Richin Chicago)
Yeah, the previous owner never sent it (or the 2nd remote). I wouldn't have made this post if I had it :)
Dope
Old Mar 6, 2004 | 06:15 PM
Richin Chicago
Dope
From the manual:
To match transmitters to your vehicle:
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver
Information Center (DIC) by pressing the
RESET button.
3. Press the OPTIONS button on the DIC several times
until the blank page is displayed, then press and hold
the RESET button for two seconds.
4. When the message FOB TRAINING is displayed,
push the RESET button once. The message
HOLD LK + UNLK 1ST FOB in the DIC
will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on
the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned (matched), the DIC
will display FOB LEARNED and then prompt you
to learn the next transmitter.
7. Repeat Steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if:
 You donÂ’t program any transmitters for two minutes.
 You take the key out of the ignition.
 You have programmed three transmitters.
You can get an online manual for free at: http://www.mygmlink.com
Register and the go to my glovebox.
[Modified by Richin Chicago, 5:18 PM 3/6/2004]
Old Mar 6, 2004 | 06:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The GM parts department has a fob checker that will tell you if it is working or not! Take it to your dealer and ask them to check it for you.
BC
Old Mar 6, 2004 | 11:31 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Training new remote? (Bill Curlee)
I recently changed the battery and it wouldn't work again. I've changed it with no problems before, but this time it only worked only once to open the door and would not set again. I got another battery and tried and it still wouldn't work...and this is when it was working before the battery.
Happily enough, I had the 2nd one that came with the car and it took the procedure find and works ok.
So I'm not sure what the problem is but I tried it 4-5 times with no luck whatsoever. The suggestion above about taking it to the dealer sounds like a good idea.
Old Mar 7, 2004 | 08:16 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Training new remote? (FunDriver)
Fun Driver
The battery connections in the fobs are a known source of problems! Take a close look at them and make sure that they are clean and make good contact with the battery. I used an ink eraser and buffed up the contacts and bent the contacts to make better contact in one of my fobs that had intermittent operations. It took care of the problem!
Be careful the contacts are easy to break off so do not bend them too far!
Bill C
Old Mar 8, 2004 | 09:11 AM
2kbluestreak's Avatar
2kbluestreak
I just did both of mine over the weekend and had a similar problem, but finally got them both trained. First, remove the key from the fob and use it for the procedure. Then hold each fob right at your left shoulder as you press the "lock" and "unlock" buttoms together. After counting to about 150 for each, I finally got the "fob learned" message. Sounds rediculous when the owners manual says the fobs are good for 100 feet, but it worked for me. :cheers:
To Training new remote?
