Sounds like marble at part throttle?
Old Mar 6, 2004 | 07:38 PM
cscollis's Avatar
cscollis
Default Sounds like marble at part throttle?
On the way home from the track, a strang clanging sound like marbles in the muffler when between 1500-2000 in OD A4 and throttle is pressed in about 1/4. All other gears are fine and the sound goes away at higher RPMs and lower RPMs.
Any ideads what could cause this and how to fix it?
Old Mar 6, 2004 | 08:11 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Sounds like marble at part throttle? (cscollis)
I noticed something similar last year coming home from the 50th anniversary activities. If I was cruising along in 6th gear under 2k rpm, I would here this "tink" "tink" sound from under the car. Would that describe what you heard? Some here told me it was carbon buildup or something, but I haven't done anything about it. Doesn't happen at all once I get past 2k rpm.
:lurk:
Old Mar 6, 2004 | 08:27 PM
magnetized's Avatar
magnetized
St. Jude Donor '09
Default Re: Sounds like marble at part throttle? (C5 StockSwap)
I've got it too, and the decarb procedure did nothing to fix it. I thought I read that it might be a loose O2 sensor bung, but I haven't investigated yet.
:steering: Ride On :seeya
Old Mar 6, 2004 | 11:45 PM
cortex's Avatar
cortex
You can try replacing the fuel filter. That fixed it for me. :steering:
Old Mar 7, 2004 | 09:56 AM
cscollis's Avatar
cscollis
Default Re: Sounds like marble at part throttle? (cortex)
TTT
Any other suggestions?
Old Mar 7, 2004 | 11:32 AM
MC TORCH RED's Avatar
MC TORCH RED
do you still run cats???
Old Mar 7, 2004 | 04:08 PM
cscollis's Avatar
cscollis
Default Re: Sounds like marble at part throttle? (MC TORCH RED)
Yep, could my cats have gone bad. It was running extremly rich for 3 months before I changed my O2 sensors.
Old Mar 7, 2004 | 08:21 PM
2001 Red Coupe Bandit's Avatar
Scott when mine was runnign rich my cats melted and it didn't make noise, it just lost power.
:confused:
Old Mar 7, 2004 | 08:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Sounds like marble at part throttle? (2001 Red Coupe Bandit)
If your CATs over heated the brick inside melts and breaks up! Get a rubber mallet and rap on the cats and mufflers. The material usually ends up in the mufflers! If you have loose material , when you rap on the componets it will rattle.
BC
Old Mar 7, 2004 | 11:28 PM
cscollis's Avatar
cscollis
:confused:
I was getting rid of the cats anyway, now I have a reason. It is either the cats or exhaust somewhere. I will take it to RPM when I get back from Houston and have them cut the cats and see if that fixes it.
Old Mar 8, 2004 | 12:18 AM
MC TORCH RED
scott drive that vette down, i just went 11.69 n/a and 11xx with a little help. :eek:
Old Mar 8, 2004 | 10:36 AM
cscollis's Avatar
cscollis
I am driving the benz but I would love to take it to the track Wednesday night if it is open.
Old Mar 8, 2004 | 05:52 PM
MC TORCH RED
:nopity you used all your luck up in hallsville, no more mr. nice guy, i want to bust you up big boy. i will even let you move on me.
To Sounds like marble at part throttle?
