New Cam - Tuning?
Old Mar 6, 2004 | 08:09 PM
broeme's Avatar
broeme
Default New Cam - Tuning?
I've been following all the cam threads lately in my continued effort to find my ideal match. Depending on the day and my mood, it varies quite a bit!! My question rates to tuning after a cam only install. Is there a general rule of thumb where a certain level of duration, lift...etc actually requires a tune? Or do the LS1s automatically adjust for the new cam; making the tune just for squeezing out some HP? Thanks in advance all! :seeya
[Modified by broeme, 8:10 PM 3/6/2004]
Old Mar 6, 2004 | 09:04 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: New Cam - Tuning? (broeme)
I strongly reccomend a tune no matter cam you end up going with.
Old Mar 6, 2004 | 09:08 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
For sure all A4s will need a tune, I had to drill a small hole in the throttle body blade to get my car home or it would die. The mechanic that installed my cam did not tune cars. The M6's are able to be driven without the hole. Both A4's & M6's need to be tuned for optimun operation.
[Modified by wallstAL, 6:10 PM 3/6/2004]
Old Mar 6, 2004 | 09:50 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: New Cam - Tuning? (wallstAL)
:iagree:
Old Mar 7, 2004 | 03:42 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: New Cam - Tuning? (C5 StockSwap)
I would recommend tuning with any cam. Do you have a stick or an auto? I have a stick and went with a 230/224. I drove mine around for about a month with no tuning. It ran fine. Just wasen't making all that it could. kaley
Old Mar 7, 2004 | 08:39 PM
broeme's Avatar
broeme
Default Re: New Cam - Tuning? (2C5only21)
My 98 is an MN6 as well. From the other advice I've gotten, it sounds like a tune is the best way to go. It's good to know that I may not have to get it immediately. Thanks everyone!
Old Mar 7, 2004 | 08:59 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: New Cam - Tuning? (Z06ufgrad2002)
:iagree: :iagree: :iagree: :iagree: :iagree: :iagree: :iagree:
Old Mar 7, 2004 | 11:07 PM
C7GrandSport's Avatar
C7GrandSport
Default Re: New Cam - Tuning? (Buckmaster)
Tuning is essential to maximize both performance and driveability after a cam change.
Old Mar 7, 2004 | 11:24 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The greater the duration and the narrower the LSA the more involved the tune becomes. I agree with everyone here - a Tune is a good idea for all cams. FWIW.
To New Cam - Tuning?
